Its hard to tell from the pics but most of those engines had sleeves. The easiest way to work that bad cyl may be to break the piston out driving from below, worst case cutting the rod into, then -putting a sleeve in that cyl bored to match what you bore the other cyl's. As wore as the engine is I would suspect it will need boring all cyls.
