12-02-2022, 03:46 PM | #21 | |
Re: rear brake drum puller
12-03-2022, 03:34 PM | #22 |
Stan
Make sur you back off the pads!!! |
12-04-2022, 09:14 PM | #23 |
Is this correct for 36? It doesn’t fit on my 37. Bought it years ago for a 36 but never used it.
Tim Carlig |
12-04-2022, 10:25 PM | #24 |
12-05-2022, 01:59 PM | #25 |
12-05-2022, 02:53 PM | #26 |
Tim Carlig |
12-05-2022, 04:08 PM | #27 |
The Vintage Precision will, I've pulled my 32 Ford & 39 Mercury with it!!! Works swimmingly, Fixing to use it on my 47 Mercury here shortly!!!..... AS advertised "28-48"
12-05-2022, 04:21 PM | #28 |
Roc, do you have a photo and the measurements of the opening? Thanks!
Tim Carlig |
12-05-2022, 04:48 PM | #29 |
12-05-2022, 04:52 PM | #30 |
Tim
Here is a photo from vintage precision's web page, as you can see, the cap that screws onto the axle end and you push against, has a long slot that it can slide in for short OR long snout hubs!!!!! As it states, it will pull from Model A's to 48 V8's!!!! |
12-05-2022, 04:55 PM | #31 |
12-05-2022, 07:09 PM | #32 |
Tim
I had a little project to finish up in my shop so sorry on the delay in getting these posted, I hope this is what you were asking for??? |
12-05-2022, 07:29 PM | #33 | |
12-06-2022, 02:50 PM | #34 |
I have the other style that gets secured behind 3 lug nuts. I like this style much better
12-06-2022, 02:59 PM | #35 | |
Until you warp a drum in the removal process.
12-09-2022, 02:46 PM | #36 |
I am also interested in the hub puller if you still have one, KiWinUS.
Thanks |
12-09-2022, 03:15 PM | #37 |
12-10-2022, 07:25 PM | #38 |
New Vintage Precision is $175. Thanks anyways
12-12-2022, 08:38 AM | #39 |
FYI
The New Vintage Precision hub puller will not work on a hub that has a protruding ring as my 37 has. Zeke |
12-12-2022, 10:09 AM | #40 |
I had that problem on my 38 too. I called them and they recommended sanding off some of the surface roughness on the ring. Worked like a charm.
