Old 11-27-2022, 01:53 PM   #1
47topless
47topless's Avatar
Default proper order of engine analysis
My recently purchased 1947 Ford, with stock V8, is not running very well. It starts immediately but seems confused under load. The only thing I have done is change the spark plugs. There was some improvement, but just a little.
Is there a proper "order of elimination" when diagnosing a poor running engine?
Should I start with a compression test to establish a baseline?
Thank you.
Phil
47topless is offline   Reply With Quote
Old 11-27-2022, 02:02 PM   #2
deuce lover
deuce lover's Avatar
Default Re: proper order of engine analysis
Vacuum gauge IMO to start with
Old 11-27-2022, 02:07 PM   #3
KiWinUS
KiWinUS's Avatar
What did plugs you took out look like.
KiWinUS is online now   Reply With Quote
Old 11-27-2022, 02:40 PM   #4
Joe B.
Joe B.'s Avatar
Check the vacuum advance unit for integrity. Not necessarily the proper order of troubleshooting, but that was the cause of a similar issue on my recently acquired '50.
thread killer
Joe B. is offline   Reply With Quote
Old 11-27-2022, 02:42 PM   #5
tubman
tubman's Avatar
I would start with a compression test, since you seem to be able to handle that yourself. The ignition? Unless you have the tools and experience in working with these, it is best to send it out someplace to have it checked, repaired (if necessary), and the timing set. Also, you can do a simple check by looking down the carburetor and see if it has a healthy squirt of gas from the accelerator discharge nozzles. There can be many things that can go wrong with these carburetors (leaky needle, leaking power valve, bad float setting, just plain dirty etc.). If you have the skill, you can go through the carburetor yourself, if not there are guys out there that are wizards with these and won't break the bank. A compression test would be a good first step, if only to ensure that there are no serious problems with the engine.
Old 11-28-2022, 02:07 PM   #6
Als48
Don't forget to check the firing order on the spark plug wires!
Als48 is offline   Reply With Quote
Old 11-28-2022, 03:00 PM   #7
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
AMEN TO VACUUM GAUGE TELLS ALL !!!!!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 11-28-2022, 03:08 PM   #8
Mart
Mart's Avatar
I would suggest that some description of the problem in more understandable terms might help in suggestions of troubleshooting.
It seeming confused is too woolly a description.
Old 11-28-2022, 04:50 PM   #9
A bones
A bones's Avatar
Meaning like this?
It seems confused under load.
Thank you.
Phil
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 11-28-2022, 07:35 PM   #10
47topless
47topless's Avatar
Thank you all for your responses. I guess there is no set order, for the process of elimination, in diagnosing a poor running engine, but a great starting point is a vacuum test. A compression test will provide some useful clues as well. Tools for solving the mystery of a stuttering engine.
Please stay tuned.
Thanks again,
Phil
Old 11-28-2022, 08:38 PM   #11
Lanny
Lanny's Avatar
Phil, when doing the compression test, hold the throttle plate open
on the carb so some air can be sucked into the cylinders to give you
the best chance at getting an accurate compression reading.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 11-28-2022, 11:25 PM   #12
47topless
47topless's Avatar
Will do. Thank you.
Old 11-29-2022, 04:45 AM   #13
Mart
Mart's Avatar
Phil, do you have another car with similar components? It is sometimes a reasonable thing to do to swap some components to see if the problem goes away.
I had a problem where the car would misfire while accelerating. It would get progressively worse until it wouldn't go at all. It would drive when cooled down.
In my case it was a bad distributor cap one time and a bad rotor arm another. So if your stuttering falls into the getting steadily worse category, it may be like that.
You might try a known good condenser that works well in another car.
You might try cleaning the points. (Easier with distributor off)
Not sure what a compression test will tell you but no harm in doing it.
Let us know what you find.
Old 11-29-2022, 06:12 AM   #14
deuce lover
I repeat and Bubba Agrees,Vacuum Gauge.Eliminates guess work.
