Old 11-13-2022, 09:27 AM   #1
38convsedan
38convsedan's Avatar
Default 1936-40 Teardrop Skirts installation?
Just received a set of the steel 1936-40 teardrop skirts for my 38.
There were no instructions provided and I am at a loss as how they install.
There is a small arm at the leading bottom edge, a lever up the center, and a small plate with a wing nut at the rear….
As always, thank you in advance!
Steve
38convsedan is offline   Reply With Quote
Old 11-13-2022, 11:00 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1936-40 Teardrop Skirts installation?
This is how I remember them.
Old 11-13-2022, 01:39 PM   #3
Lawson Cox
Lawson Cox's Avatar
Leave them off. The car will look better. Just my 2˘.
Old 11-13-2022, 02:21 PM   #4
ford38v8
ford38v8's Avatar
Lawson is correct. If a Ford accessory just maybe, but aftermarket definitely not.
You’ll have to decide before you install, because they’ll mess up your paint job.
Alan
Old 11-13-2022, 03:17 PM   #5
38convsedan
Thanks ‘51 Merc—your directions were very helpful.
I appreciate other comments too, but I happen to love them!!!
Old 11-13-2022, 07:02 PM   #6
FlatheadTed
FlatheadTed's Avatar
Steve We just fitted a set to a 37 sedan ,they were to small to fit so we added a bead of stock around the edge at the owners request .At the lower corners we modified the fixings that were provided ,like welding in a section of tube so that it could sit in the 1/2 round section of the fender .so no chance it could jump out .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-13-2022, 07:31 PM   #7
swoopNZ
MEMBER EMERITUS
Original 37 fender skirts are larger than 38/39 ones.
swoopNZ is offline   Reply With Quote
Old 11-13-2022, 08:24 PM   #8
FlatheadTed
Yes wrong year ,that's likely why we had to modify these
Old 11-14-2022, 04:24 PM   #9
slowforty
slowforty's Avatar
I got a nice set for my 40.
Was a pain in the ass to install.
Took a few pictures with the skirts on,
And then put them back in the garage attic
slowforty is offline   Reply With Quote
