#21 | |
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#22 |
Pat.. interesting i am going to try that experiment tonight thank you
#23 | |
#24 | |
Will report more when i do these things and thanks again!
#25 |
Jumping in late, here, but I had the same problem. It seemed to happen most -- every time! -- I left the church parking lot! Not being one to hang around for cookies, I (we, Jan kind of agreed about the cookies) was usually first out and down the drive. Whooosh. He'd die. Then, the rest of the congregation would catch up and have to get out of their cars and give me a push.
I "fixed" the problem by giving the carb I'd rebuilt to a very talented hired guy who made it work like a champ. No more problem. No more sweaty friends. |
#26 | |
#27 |
HIRED GUN -- not hired guy. Sorry Howard.
#28 |
It just needed a touch of the master's hand. Zeinth's know when they are put together correctly ... by an amatuer!
#29 |
i had a fuel starvation problem and how i confirmed if it was the carb or the fuel delivery system was when it died out i turned off the fuel shutoff right away to not let any more flow to the carb. then pulled off the carb and opened the bowl to see where my fuel height was. in my case the fuel height was very low and the problem was the line was pushed to far in the carb..
#30 |
Banned
Fuel Delivery or spark died. Best guess. In no particular order...
Fuel Compression Spark Timing It has to run. Says so in the book. Interestingly enough at our spring Model 'A' clinic George showed the fellows an after market cheap set of points bolted properly down to the upper plate. Spark: Well let me tell ya, the Cooper conductor wrapped to the same rad [arch] as the piece of spring steel would bulge out at low speed and go to ground. Cutting off the spark. Not so bad at higher speeds. Everybody had a chance to see the damaged conductor area where the spark jumped to ground. Like a miniature weld. Gas delivery: Clean the screen, a lot. Pull the line off the carb. Turn on the gas see if it flows. It likely does. Carb. Float, float valve, a sticky shut-off from the float valve, main jet fouled, sticky green gelatinous mess from ethanol. Any air filter in the way of air sneaking up the carb. Gas tank venting? No after market fuel filters in the way of gas flowing. Timing, warms up points move, spark goes away. You do have a positive drive between the cam to oil pump, and cam to distributor. Nothing that is suppose to be 'cogged together' just turning with friction after a shaft broke. Honest! I had a 1500 cc VW with a broken crank shaft. It ran but not well. Two complete pieces. Anyway... Compression. I don't think that's the problem. I know this is no help. I'd start over with a very very good tune up. skip. |
#31 |
I has a simaler thing although in my case it would just die and coast over to the side of the road then wouldn't start for 10 minutes and then would run fine. I cleaned the carb about 15 times and rebuilt it twice and never fixed it . Turned out to be an intermittent fault in the ignition lock. Karl
#32 |
I had the exact same symptoms with mine. I tried all the above remedies to no avail. Finally, I decided to go through the wiring piece by piece. The first thing I did (just by luck) was to take the instrument panel off. I found that one wire to the ignition switch had a loose nut and was just hanging on by a small thread of wire. Once I fixed that, it hasn't happened again.
#33 |
Dear Mark Maron,
1st off, thank you for you excellent problem description. Did you fix your sedan as yet? I searched The Barn for the exact problem you were having. Why? Because my 31 Coupe has the same exact problem. Next I want to thank all you flathead enthusiasts for sharing your years of knowledge and learned experience! After reading the advice given to fix Mark's problem, I made the following checklist: - Wire connections - Change condenser - Drain fuel at Zenith - Pull bottom of carb & blow out - Emty fuel tank & look for junk - Open sediment bowl & check for flow there - Do carb Heimlich maneuver - Fuel flow at carb line like 14 yr. old not 63 yr. old (me!) - Remove shut-off valve and check for junk The results were amazing! Bug wings & bodies and sand in carb filter! Lots of small grit/sand in float valve! Fuel flow at carb end of line like a 63 yr. old after waiting too long...just a drizzle! Pulled bottom off sediment bowl...full of grit, rust & bug parts! Pulled fuel shut-off valve...completely plugged! Looked inside fuel tank...saw some rusty-looking small patches on bottom but no loose junk...apparently everything washed downstream! I fired that mother up by noon today (already about 90 degrees here in Carthage, NC) and she ran good. So I took her out on the road for a cautious drive. After 5 miles she still purred like a kitten, I ripped along at up to 50 mph...no problems. So I got really confident and did some joy riding...big grin on my face! By the time I got back to the workshop, I had put 30 miles on her. No coughing, no "vapor lock", no engine quitting like before!!! A big thanks again to Mark for asking the right questions and you other folks for being so good as to take the time and offer your best shots. Blessings to one and all! |
#34 |
I had the same problem with my car. I rebuilt the carb and did most of what has been suggested here. Eventually I traced it to an intermittent fault in a replacement ignition switch. Replaced the switch and no problems since . Good Luck Karl
#35 |
I had a problem like that with my 31 coupe. I finally was able to see (with a flashlite) something floating in my gas tank. I got a coat hanger and fished out what looked like a piece of burlap. It was about the size of a silver dollar. It just drifted around and would settle ever so often over the feed to the sediment bowl. I remember being so mad that day. She had sputtered out on me twice. When I got that piece out of the tank I stopped on it all the way home. I was flying !!! Probably hit 37 0r maybe even 40.
#36 |
Running ethanol gas? Running a cork float? They dont play well at all. Replace with neoprene before you get a tank full of cork crumbs to clean out. I think the cork particles still have enough "float" to rise up out of the blocking position when vacuum is released when the engine dies. Small outboard motors with integral fuel tanks can drop tiny plastic shavings into the fuel line/jets. A real pain to blow them out.
Been there, done that.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
#37 |
A lady in our club had the same problem with her dad's coupe. Turned out there was a leaf floating in the gas tank and would occasionaly float over the outlet/shutoff. I put in a stand up screen filter in the shutoff and it worked fine.
#38 |
I'm running into a similar problem and didn't even think about the gas cap till I read it in this post. I had heard of this vent issue before but it didn't even click that I swapped caps around the time this issue started. Is partially opening the cap the only solution to this. Can it be vented another way or vents opened.
Bob
"Fix what's broken" |
#39 | |
#40 |
I had the cap vent problem described by Pat. I drilled through the original vent hole in the center piece. I tapped the hole for a small screw and locktited in place. This locked the gasket to the cap center so it could not rotate to block vent.
I then drilled a new vent hole on the opposit side of the original hole. Be careful to only drill through the center and not the outer cap. This has worked well for several years . John |
