Old 10-19-2022, 06:33 AM   #1
chuck stevens
chuck stevens's Avatar
Default 47 u-joint help
Anyone have short cuts for replacing a u-joint? Has anyone used the new joint with needle bearings? Thanks, Chuck.
chuck stevens is offline   Reply With Quote
Old 10-19-2022, 10:16 AM   #2
oldskool
oldskool's Avatar
Default Re: 47 u-joint help
there is a problem with the repro lincoln ujoints they dont go deep enough and draw the output shaft up tight, find a good used original, u will need to pull the rear to get at the joint
oldskool is offline   Reply With Quote
Old 10-19-2022, 10:49 AM   #3
19Fordy
19Fordy's Avatar
Sadly, there are no shortcuts. Here's a good thread about pulling the 1948 Ford rear, which I think, is the same as a 1947. Some say you don't need to remove the rear spring when pulling back the rear. That is true IF you can raise the rear frame of the car high enough for the rear spring to clear the rear cross member into which it fits. Removing the rear wheels so you can lower the rear so it's resting on the drums really helps. You can still roll the rear on the drums. You have to disconnect the brake line up near the front of the wishbone where it crosses over from the master cylinder.
https://www.jalopyjournal.com/forum/...-ford.1064240/
Follow oldskool's advice re: U-joint.
BE SURE TO USE LOTS OF JACK STANDS TO SUPPORT THE FRAME OF YOUR CAR WHEN LIFTING IT.
You can rebuild your OEM U -JOINT but, it would be nice to find an OEM original.
https://thirdgenauto.com/product/192...nt-repair-kit/
or you can by one already rebuilt (easier than doing it yourself).
https://www.dennis-carpenter.com/car...niversal-joint
One more thought, while you have easy acessability you might want to replace the old style cork seal in you U-Joint bell with the neoprene seal and also seal #4245 shown in last photo.
https://www.ebay.com/itm/25125522858...Bk9SR6apk5D-YA
PS: Don't forget to install the two paper gaskets BEFORE you reinstall your U-Joint.
The 3rd photo is that brake line you have to disconnect in order to roll the rear back. If that line were longer, you wouldn't have to bleed the brakes.
Old 10-19-2022, 12:04 PM   #4
bobH
YES, to everything posted in #3 by Fordy. I've done he job a few times, both on my 47, and another 48. No big deal. Spring stays with rear end. And, if some kind mechanic before you put on the front hose in place of the short factory hose, then no need to disconnect the brakes. A pretty quick job, once you set your mind to it. (And, assuming you have the skill and equipment.)
bobH is offline   Reply With Quote
Old 10-20-2022, 06:45 AM   #5
chuck stevens
Thanks guys, this job is like going to the dentist... the worry is worst than the job itself, thanks again.
Old 10-20-2022, 11:37 AM   #6
corvette8n
corvette8n's Avatar
Is 1941 the same procedure?
Old 10-20-2022, 01:54 PM   #7
meric42
meric42's Avatar
Originally Posted by corvette8n View Post
is 1941 the same procedure?
yes.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 10-20-2022, 05:53 PM   #8
19Fordy
19Fordy's Avatar
Be careful as it's easy to pinch your finger when trying to side the drive shaft splines into the U-joint.
