Old 08-29-2022, 08:22 PM   #14
Don
Don's Avatar
Default Re: 1935 Wire Wheel Backspacing and offset
I took some 3/16 rod !made a ring the size that fit the rim ,welded it togeather to form ring
then laid in in wheel,put a straight across the holes from one to the other then ground the ring to be flush with lug holes,,made a little clip to hold them in place when you put wheel on,,,I believe it helped some with the wiggle,I only needed them on front.
DON P
Don is offline   Reply With Quote
