Old 08-24-2022, 05:07 AM   #1
32Bee
Default Optima 6 Volt Red Top Battery
What's going on with the Optima 6 Volt batteries? I ordered one from Batteries
Plus months ago and it has never been shipped to me. Every time I call for an
update, they just keep saying they are on back order. Ecklers says the same
thing. Are they no longer going to be produced?
32Bee is offline   Reply With Quote
Old 08-24-2022, 06:05 AM   #2
Jacques1960
Jacques1960's Avatar
Default Re: Optima 6 Volt Red Top Battery
NAPA has them in stock
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 08-24-2022, 06:19 AM   #3
Lincoln29
I had the same issue from MAC and finally cancelled the order.
Jerry
Lincoln29 is offline   Reply With Quote
Old 08-24-2022, 06:25 AM   #4
chuck stevens
chuck stevens's Avatar
Peter, the latest Optima batterys are made in mexico and don't hold up as good as the originals. Be sure to check it out, maybe they're doing you a favor.
chuck stevens is offline   Reply With Quote
Old 08-24-2022, 02:35 PM   #5
supereal
supereal's Avatar
I ordered a new Optima a couple of months ago, as the original finally wore out after seven years. We use Interstate Battery as our supplier, and it took several weeks to obtain the battery. The benefit also was a lower price than of many of the usual vendors.
supereal is offline   Reply With Quote
Old 08-24-2022, 03:21 PM   #6
32Bee
I called and spoke with four different local NAPA stores. None of them had any or feel they
knew when any would be available. One guy even called the manufacturer directly and even
they couldn't or wouldn't say when any would be available.Thanks for your responses.
Peter
Old 08-24-2022, 04:56 PM   #7
Jacques1960
Ugh, sorry to hear that
Old 08-24-2022, 05:44 PM   #8
TMarsh
Optima lasted 14 months, ORielly auto parts gave me my money back and I bought a conventional 6 volt battery. I was not going to wait on Optima, I am ready to ride.
TMarsh is offline   Reply With Quote
Old 08-24-2022, 10:28 PM   #9
Tinker
Tinker's Avatar
I have one that's 10 yrs old made in mexico.
It's probably not a high demand battery. So harder to find. I hope they still make them. At least at a limited supply.
Old 08-25-2022, 03:22 AM   #10
koates
Optima batteries like any other product manufactured by man occasionally produce a faulty one. Optima batteries are a top notch product and I have had 18 years use out of one and 10 years plus out of others. Why do emergency services use them in their vehicles I wonder. Just because you have had a bad one there is no need to bad mouth them. Many high quality electrical components are manufactured in Mexico for many years. OPTIMA batteries are one of the very best you can buy. I have fitted and used hundreds of them over the last 25 years in a large Fire department. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-25-2022, 03:55 AM   #11
koates
Meant to say that the 6 volt Optima batteries are only made in batches as required or when production allows because of their lower demand and therefore sometimes are out of stock. Think ourselves very lucky that they are made at all. Regards, Kevin.
Old 08-25-2022, 06:03 AM   #12
ronn
you might try Amazon for your optima..........
the prices have become crazy for sure.
Old 08-25-2022, 08:17 AM   #13
Chris in MA
Chris in MA's Avatar
I gave up on the Optima batteries. First one lasted 9 years, second one lasted three. Went and bought a conventional 6 volt at Auto Zone and its been much better.
Chris in MA is offline   Reply With Quote
Old 08-26-2022, 10:35 PM   #14
john greco
Agree with koates , I’ve used at least 20 6 v in last 20 years and 20 , 12 v , had two 12v that lasted less than a year but they gave me new ones and most fail after 10-12 years I think there superior compared to conventional acid battery’s that cause corrosion, from fumes , or acid , most 6 v I install horizontal to allow for dual ex
john greco is offline   Reply With Quote
Old 08-29-2022, 10:09 AM   #15
Fritz
Fritz's Avatar
Got my new one this summer at a local Advance Auto Parts. It was 10 months old, but it’s working well and holding good charge. There is a shortage for some reason. I am in the camp of being glad I even got one, and that they are being made at all.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 08-29-2022, 10:50 AM   #16
slowforty
As with Amazon Get the credit card. They will give you money off, depending on huw much you spend. I got two batteries from them and got $150.off
slowforty is offline   Reply With Quote
