Old 08-24-2022, 01:08 PM   #1
Mart
Mart's Avatar
Default Excessive crank end float.
What problems are associated with excessive crank end float?
I have a crank that is in nice condition but when assembled up it has .020" end float. The motor starts up ok, I haven't driven it yet.
What, if any problems can I expect from this situation.
It is a French motor so has 59A type cam gears which thrust the cam towards the block and subsequently there is a forward thrust on the crank. This is the same direction as clutch release thrust.
So in this case would it be reasonable to think that the crank might tend to spend most of it's time at the forward limit of travel and not switch back and forth? Or do you think it would drift towards the rear location during acceleration?
I don't really have much choice as I want to run it at the weekend but I was wondering if excessive end float is more of a less than optimum thing or is it definitely a complete disaster.
Mart.
Mart is online now   Reply With Quote
Old 08-24-2022, 02:17 PM   #2
Brian
Brian's Avatar
Default Re: Excessive crank end float.
I cannot answer your question, but what I've done in the past in this situation, is I've built up the thrust faces on the bearing with babbit and machined to suit.
Old 08-24-2022, 02:19 PM   #3
cas3
It may have a sound like a loose main bearing when going off and on load driving conditions. Spec is about .08 IIRC
cas3 is online now   Reply With Quote
Old 08-24-2022, 05:00 PM   #4
cadillac512
cadillac512's Avatar
Hi Mart. At .020" end float I wouldn't expect any problems. Not optimal for sure, but not a disaster either.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-24-2022, 06:24 PM   #5
Pete
It is not going to last very long with that much clearance. You need to determine what the problem is first.
Is the thrust bearing worn? If so, possibly a new one will cure the problem.
Is the block saddle worn? If so, sleeving the side of the saddle will cure that.
Is the crank thrust worn? If so, it can be welded and re- ground.
Old 08-24-2022, 06:27 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
The thrust surface width on your nice condition crankshaft is worn so to reduce the end play a bit here's what you can do. Flare the thrust surface out just a touch on the main bearings. Wont take much to reduce the end play down to the max which is .006 according to the books I work from. It would take a long time before any wear is seen in the bearing if you decide to just flare the bearing thrust surface out a slight amount.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 08-24-2022, 06:34 PM   #7
Yoyodyne
Yoyodyne's Avatar
How is that done?
I've read here in the past that the bearing shell can be shimmed a few thousandths to adjust end play, is that a reasonable thing to do?
Yoyodyne is offline   Reply With Quote
Old 08-24-2022, 07:11 PM   #8
Ken/Alabama
Ken/Alabama's Avatar
My way of thinking is how does that much end play affect the rods with it thrusting fore and aft ? I’m thinking not good.
Old 08-24-2022, 07:50 PM   #9
Kube
Super Moderator
Kube's Avatar
.080"? You sure about that? That seems like a mile. That's just shy of 1/16".
Old 08-24-2022, 07:51 PM   #10
Kube
Super Moderator
Kube's Avatar
Ronnieroadster
Ronnie, .006" sounds much more credible than the .080" that CAS3 posted.
Old 08-24-2022, 08:09 PM   #11
Pete
Originally Posted by Yoyodyne View Post
How is that done?
Same principal as if you were sleeving the middle of the saddle. You bore away about .080 from the area covered by the side of the shell, then make a flat curved piece to fit in the bored away area. Make the insert about .010 to .015 thicker than the finish thickness for the saddle.
Clamp the new piece in place with a generous amount of Loctite and drill 4, 1/8 holes evenly spaced across the piece. Take a short piece of 1/8 brass welding rod, coat the tip with Loctite and drive it in one of the holes till it bottoms. Do the other 3 the same way. Take the clamp off.
Using a fine tooth jewlers saw cut the excess brass off of the pins. Now peen what is left down till it is flush.
Face and bevel the insert to finish size.
NO, you can't shim a bearing shell and expect it to live.
Old 08-24-2022, 09:24 PM   #12
Yoyodyne
Yoyodyne's Avatar
Thanks for that description Pete.
The shims I read about here were behind the thrust surfaces only, much like the inserts you describe. So you say that does not work? Is it because of lack of heat transfer?
Old 08-24-2022, 09:32 PM   #13
Pete
If there was some positive way to hold them in, they might work.
Heat is not a problem.
Old 08-24-2022, 10:19 PM   #14
cas3
So sorry...I left out one zero ! At any rate, I still think you will hear a knock like a main bearing, and agree with ken, rods won't like the thing moving around. I would fix, or not use it
Old 08-25-2022, 01:58 AM   #15
bbrocksr
1/16th =.0625, .080 is over 1/16th
Bill
bbrocksr is offline   Reply With Quote
Old 08-25-2022, 03:07 AM   #16
Mart
Mart's Avatar
Crank is low miles French military rebuild. Bearings are brand new. Saddle is not worn.
I think the French military might have ground the cranks oversize on the thrust faces and had access to oversize bearings to suit.
I have a crank with a damaged thrust face. Can someone give details on the welding process to build up the thrust face?
For example, what type of welding? Mig? Arc/ what type of wire or rod? Special gas?
If normal mig welding and wire I could try myself. Ditto if arc if I know what rods to use.
Thanks for the input so far..
Mart.
Old 08-25-2022, 04:44 AM   #17
Brian
Brian's Avatar
Mart, What I've done a coupla times now is to build up the faces on the bearing. use a big iron and some whitemetal. easy peasy; the faces are already 'tinned' so to speak, just need a bit more of a build up each side. Then machine the built up faces to acheive your desired clearance. you say you've got .020" clearance. You only need an additional .007" on each face. In effect, you're making oversize bearings as you claim the French had access to.
Personally, I don't like welding cranks, can be done, but a lot of work!
Old 08-25-2022, 05:15 AM   #18
Fatheads4ever
Fatheads4ever's Avatar
Hi Mart.. take the soft option. You could look at metal spraying the trust surfaces of the bearings. Then mill or sand them to suit. I like Brian's idea.
Just a thought.
Regards Kevin
Fatheads4ever is offline   Reply With Quote
Old 08-25-2022, 06:36 AM   #19
Terry,OH
Terry,OH's Avatar
Crank can be welded and reground to reduce to proper Specification.
Old 08-25-2022, 07:27 AM   #20
Kube
Super Moderator
Kube's Avatar
Bill
Thanks for waking me up. Good grief!
