Old 08-12-2022, 11:44 PM   #9
panhead_pete
panhead_pete's Avatar
Default Re: Water Pump shaft end play
Thanks all. I have fitted a split collar (16mm) and set the end play at .007. Its an interim fix as Im not really comfortable with the collar riding against the pack nut.
Whilst I was doing that checked the fan and its aluminium but does have some play in it too. Will order a fan whilst Im there as freight will be the biggest expense.
In the absence of new leakless pumps being available affordably has anyone used the Bratton unasembled water pump kit?
https://www.brattons.com/30-31-LEAKL...uctinfo/12220/
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
