Old 07-21-2022, 12:09 PM   #1
vangogh
Default Watter Wetter
Hi Barners,
Has anyone used Water Wetter to reduce the temps in the radiator? How has it performed?
best
Paul in AZ
vangogh is offline   Reply With Quote
Old 07-21-2022, 12:28 PM   #2
Big hammer
Default Re: Watter Wetter
Water + water wetter as compared to anti-freeze, about 25*F cooler
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 07-21-2022, 01:05 PM   #3
vangogh
Hi Big Hammer,
Does that mean you use water wetter instead of anti-freeze? What about using it in the winter. Our temps get down to the teens where we are in AZ
Old 07-21-2022, 03:38 PM   #4
Lenny Bruce
From what I’ve been told water with water wetter will not protect the cooling system from freezing/cold weather damage. From my sources they recommend replacing the water and water wetter with anti freeze run it through the system thoroughly before winter driving and or storage.
Lenny Bruce is offline   Reply With Quote
Old 07-21-2022, 04:19 PM   #5
john in illinois
john in illinois's Avatar
Water Weter does not protect against rust. You need soluble oil or antifreeze to keep from eating away at your block.
Water Wetter calls out 15% antiifreeze for street engines.
John
File Type: jpg 3C0822EE-FDF9-40FE-9ECC-3377A1FA32B3.jpg (80.8 KB, 41 views)
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-21-2022, 05:42 PM   #6
Big hammer
Originally Posted by vangogh View Post
Hi Big Hammer,
No I use antifreeze now with new Berg’s radiator last year before he went out of business. Before that I tried and used water plus additives
Old 07-21-2022, 05:46 PM   #7
Big hammer
John Red line says provides excellent corrosion protection in iron aluminum brass, corrosion is rust with iron blocks IMHO
Old 07-21-2022, 05:59 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Yes, I’ve used it. It does help, but the problem is a dirty radiator/block. I don’t use antifreeze, so I use a radiator/ water pump lubricant.
Old 07-21-2022, 06:20 PM   #9
1crosscut
1crosscut's Avatar
If you must use water wetter to reduce the temperature enough to prevent boiling over you have a problem that needs to be fixed.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-22-2022, 10:57 AM   #10
katy
katy's Avatar
Originally Posted by john in illinois View Post
Water Wetter calls out 15% antiifreeze for street engines.John
15% antifreeze only protects down to 20° F, about -7° C
Old 07-22-2022, 11:47 AM   #11
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Spring water, water wetter, and an anti rust/water pump lube from NAPA works well for me. I drain and put in a new combo each spring. Summers in my area are routinely in the 100 degree range. I have the 4 row radiator and my A never goes over 180 degrees. It can also freeze in Northern California during winter months. When it does, I just put a bucket under the petcock valve and drain. My understanding is that spring water with water wetter cools best.
Dick M is offline   Reply With Quote
Old 07-22-2022, 02:56 PM   #12
JOHN CT
JOHN CT's Avatar
I agree 100%
Fix the problem! Model As never used water wetter back in day. I use 50/50 antifreeze year round and I have no problem what so ever
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 07-22-2022, 04:10 PM   #13
talwrench
When i did a test about three years ago with water wetter by a company with Purple in their name, don' recall exact name they advertise 5 to 8' cooler than 5o-5o antifreeze. I got 5 degrees cooler on long trips in 98 degree weather.
talwrench is offline   Reply With Quote
Old 07-25-2022, 04:20 PM   #14
john in illinois
Katy,I think that is for the corrosion properties and additives in antifreeze,not freeze protection.
John
Welcome each day
Old 07-26-2022, 10:10 AM   #15
katy
katy's Avatar
Deleted
Old 07-26-2022, 01:47 PM   #16
Chris Haynes
Chris Haynes's Avatar
I use Evans Waterless coolant. No Water=No Rust. Good to 40 below zero. https://www.amazon.com/EVANS-Cooling...jaz10cnVl&th=1
1921 Runabout
1930 Tudor
Early 1930 AA
Old 07-26-2022, 08:16 PM   #17
Gene F
Gene F's Avatar
I got Evans to send me some info when putting a new Chevy 350 in my streetrod. Turns out the chart they sent me shows heat transfer is not as good as water, or anti-freeze. I went with Prestone.
Old 07-27-2022, 10:15 AM   #18
katy
katy's Avatar
"shows heat transfer is not as good as water, or anti-freeze."
That doesn't make sense, it's advertised as as "Improves heat transfer"
Old 07-27-2022, 08:06 PM   #19
cokefirst
I use the Evans coolant in my AA truck and I love it. before I use it, I had the radiator spitting water out on hot days. I cleaned the radiator, removed all the water and put in the Evans waterless coolant and the problem is solved. Since the Evans has a very high boiling point of 375 degrees Fahrenheit. The heat transfer properties are not as important as keeping the coolant in a liquid state is important to transfer heat. boiling liquid does not transfer heat as well as liquid.
cokefirst is offline   Reply With Quote
