07-15-2022, 12:45 PM | #1 |
Antenna connection
Install of windshield antenna has come to a halt…
The antenna lead won’t fit in the female end of antenna cable. Is there a transition connector for this? |
07-15-2022, 01:04 PM | #2 |
Re: Antenna connection
I havent hit that point yet, but in researching correct parts, it appears the aftermarket leads dont make much sense like that.
Still figuring it out as well..... |
07-16-2022, 11:45 PM | #3 |
Problem solved!
The problem was with the female cable end. I took a small uni-bit and by hand very slowly turned the bit to slightly enlarge the opening. The antenna lead then snuggly plugged in! |
07-17-2022, 12:08 AM | #4 |
