Old 07-05-2022, 12:07 PM   #11
Bored&Stroked
Bored&Stroked's Avatar
Default Re: My COIL EXPLODED
The 40001 coil is designed for a 12V application and - and is a 1.5 Ohm coil. The instructions for the coil say that you should have a direct 12V feed to it - and you should NOT have an in-line resistor installed. (They talk about bypassing the resister if the car has one). So, I'd do exactly as they say . . .
