06-28-2022, 05:28 PM | #1 |
Clutch and brake pedal shaft removal???
Just wondering if anyone has removed this on a 1930 model without taking the transmission out??? I’ve thought about trying to cut part of it off and weld something like a slide hammer on after grinding the head off the pin and driving it down. Tell me where I’m wrong or how you did it in the car?? Thanks for the information.
06-28-2022, 06:19 PM | #2 |
Re: Clutch and brake pedal shaft removal???
This came up recently.
https://www.fordbarn.com/forum/showthread.php?p=2136222 The difficulty in my opinion is the removal and installation of the rivet that holds the shaft in place. I did it with the bell housing out of the truck and it was not easy.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
06-28-2022, 06:36 PM | #3 |
I have done it 4 times and have demonstrated it to the TCMAFC Club and Mid State A's. You need to have access to a Oxy / propane or Oxy acetylene torch in order to put some heat into the areas you need to work. additional items needed which help greatly is an air hammer and you can make a puller from common plumbing parts but you will need someone to make a quick weld to create the puller tool. I have some video clips and a power point that I used but had to supplement with me talking about the steps as the videos and still photos came up on screen. I don't know how I could place those up here. If "History" wants to make contact with me send me a message.
07-03-2022, 09:41 AM | #4 |
Thanks again for your offer to show me how to do this task. I was in the building with my thinking but not in the correct room, ok I was still out on the street but I knew there had to be a way. Your way is genius and thank you for sharing!!!!
07-22-2022, 11:24 AM | #5 |
I wanted to thank MLeder publicly for his offer to show me how to do the removal of the clutch/brake shaft. I was lucky in that I didn’t have to use any heat but still used his process in general. It worked great and success was achieved
07-23-2022, 12:15 PM | #6 |
Thanks again MLeder for the great advice!!!!! Now what other bits of awesome knowledge can I get from you???? 😉 |
10-23-2022, 08:10 PM | #7 |
Mleder it won't let me send a private message to you but I would like to see how you have done it. Thanks
10-23-2022, 08:46 PM | #8 |
I personally would not attempt it as you ae likely to paint yourself into a corner. I have done countless numbers of them, and all on a workbench. Attached is how I do them.
https://www.santaanitaas.org/wp-cont...or-Version.pdf Tom Endy |
10-23-2022, 11:44 PM | #9 |
My limited experience is that the shaft is going to fight you, there is not much room to work, remember there is gas close by, if the shaft requires replacement there are probably more wear close by, and you will be pulling the transmission before long. This is just a teaser.
10-24-2022, 07:54 PM | #10 |
Bob is right but where’s the excitement in doing it right the first time. Odds are really good as he says that more stuff is worn and will need work soon but if yours goes as easy as mine did it’s worth trying to get a few miles.
10-24-2022, 09:36 PM | #11 |
Guess it's called experience, and there's only one way I know to get it.
10-25-2022, 08:43 PM | #12 |
Thix : Check your message box, I don't know how you tried to contact me but the details to do so are there. I would be happy to explain how I go about it.
