Old 02-26-2012, 01:41 AM   #1
tbauer
tbauer's Avatar
Default 60 hp water pump removal
Hello all,
I recently picked up a 1937 60 hp. The water pumps are froze up and won't turn with out a lot of force. I bought rebuild kits from Mac at Van Pelts and he is a great source of info but I'm still looking for a little help. Is there a place I can buy the proper wrench to remove the pumps ? They are the internal type and I believe a spanner wrench is needed . I would appreciate any leads on repair manuals also. It will run if I pour gas down the carb so now I'm going thru from the gas tank forward to clean her up. Thanks ,Ted
tbauer is offline   Reply With Quote
Old 02-26-2012, 09:12 AM   #2
MARVIN, CT
MARVIN, CT's Avatar
Default Re: 60 hp water pump removal
I found a spanner wrench, the kind used for fire hoses, works pretty well. Marvin
MARVIN, CT is offline   Reply With Quote
Old 02-26-2012, 10:23 AM   #3
tbauer
tbauer's Avatar
Thanks Marvin.
I was told a plumbers wrench would work , but the ones I've found at the box stores are not up to the job. There's not much room with the fan pilots on and I don't want to break them.
Old 02-28-2012, 02:49 PM   #4
Gary in MN
Gary in MN's Avatar
Hi tbauer : I use an old J. H. Williams adjustable hook spanner # 471, 3/4" - 2".
Mc Master Carr list one as part # 5471A11 in my old catalog. You can try online for a current price.
I have attached a picture. Most V8 60 HP pumps are/were removed or tightened by using a punch and hammer so the notches may be not as sharp to catch the spanner. Lots of soaking and patients will go along way. There are two styles, tapered and straight. The newer kits should cover both. The pulleys tend to break. Once apart square up the notches. Gary in MN spanner.jpg
Gary in MN is offline   Reply With Quote
Old 02-28-2012, 03:26 PM   #5
tbauer
tbauer's Avatar
Thanks Gary i was tempted to beat on it with a drift but I didn't want to make matters worse !
Old 03-03-2012, 07:09 PM   #6
tbauer
tbauer's Avatar
Well I got the pumps out but not without destroying one. So now I'm searching for a replacement. If anyone has a pump body to sell I sure would appreciate it. Thanks
Old 03-03-2012, 09:55 PM   #7
3738
3738's Avatar
You need to tell everyone if your pump's threads are tapered or square into the bore...
3738 is offline   Reply With Quote
Old 03-04-2012, 10:41 AM   #8
tbauer
tbauer's Avatar
Here is a diagram of the water pump I'm looking for.
Old 06-19-2022, 07:55 PM   #9
Rockabilly Rodder
Rockabilly Rodder's Avatar
L-head
I can't PM you back as I don't have enough posts. I definitely want the parts. Thanks!
Rockabilly Rodder is offline   Reply With Quote
Old 06-20-2022, 02:20 AM   #10
34fivewindow
34fivewindow's Avatar
37 should have tapered pumps.
34fivewindow is offline   Reply With Quote
Old 06-20-2022, 05:04 AM   #11
KiWinUS
KiWinUS's Avatar
I have NORS PUMPS I can sell you. I will only sell in pairs.
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 01-06-2025, 06:58 PM   #12
Lisas38
Lisas38's Avatar
This post is for anyone who finds their way here looking for the spanner to remove water pumps from a v8-60. I ordered the referenced J.H. Williams wrench in post #4. It was too thick to fit between my pulley and the pump housing. I found a JW Winco wrench A52-55 Hook Wrench w/Nose that worked perfectly on my pumps. Part number A54650.
Dan
'38 V8-60 Tudor Humpback
Lisas38 is offline   Reply With Quote
Old 01-06-2025, 08:39 PM   #13
Zeke3
Zeke3's Avatar
Thanks Dan for providing that missing nugget.
Zeke3 is offline   Reply With Quote
Old 01-06-2025, 08:50 PM   #14
KiWinUS
KiWinUS's Avatar
Just an FYI. These pumps can be difficult to rebuild without the correct tools.
Old 01-09-2025, 01:25 PM   #15
Lisas38
Lisas38's Avatar
Would you explain the difficulties a bit KiWi? I've got the Van Pelt rebuild kits and have started taking mine apart. It will take a good bit of soaking just to get one of the springs to slide out. The other wasn't too bad. I'll have my son press the pulleys off at his shop and press the new shafts in. It seems like the threaded body part should slide off leaving just the shaft in the pulley, but mine don't want to come off. I'd hate to miss something critical.
I just discovered a cutaway view of the pump that explains why the pulley, shaft, and housing all have to be pressed.
Dan
Old 01-09-2025, 05:40 PM   #16
L-head
The notched nut should rotate on the pump body. The nut will slide off the pump body when they are aligned properly. Be extra careful with the pulleys. Usually rebuild kits work on the tapered or the flat face pumps.
L-head is offline   Reply With Quote
Old 01-10-2025, 06:55 AM   #17
Tim Ayers
deleted post. Nothing to add
Tim Ayers is online now   Reply With Quote
Old 03-14-2025, 02:19 PM   #18
Lisas38
Lisas38's Avatar
I’m looking for a pulley for the straight v8-60 pump. These cast pulleys must be pretty brittle as I had one broken at a machine shop when they tried to remove it. If anyone has a pulley or a too-bad-to-repair pump with the pulley on it, I’d appreciate being able to take if off of your hands.
Thanks,
Dan
Dan
Old 03-15-2025, 12:01 PM   #19
Lisas38
Lisas38's Avatar
Thanks for offering a pulley BarnFind08. Unfortunately I still need to make two more posts after this one before I can PM you. Would you please PM me your preferred method of contact?
Thanks
Dan
Old 03-15-2025, 12:47 PM   #20
barnfind08
Email [email protected]
barnfind08 is online now   Reply With Quote
