Old 06-18-2022, 04:37 PM   #29
DavidG
DavidG's Avatar
Default Re: KR Wilson spring spreader
The Snap-On spreader in #54 above is clearly is oriented toward Model A rear springs situated directly above the rear axle rather than behind the rear axle. It does not look as safe to use as the later K.R. Wilson version with the safety catches on the ends.
To spread the '32-'34 front springs we made a reduced-size version of the KRW rear spring spreader.
