Old 05-26-2022, 11:33 AM   #1
jg61hawk
Default Towing Hook Up Question
I thought I read /heard somewhere that if you do breakdown and need a tow they shouldn't hook onto the front axle to pull the car up onto the flatbed, and they shouldn't pull down hard on the front axle after the car is loaded.
I guess that would mean pull on the front bumper and or bumper brackets and then use tire straps for holding down the car.
I don't know if this is correct so any comments on this would be appreciated. I'm driving to the MARC Meet in Morgantown and while I don't think I'll breakdown, I'd prefer not to make a bad situation worse by ruining the front end. Thanks for the help.
Jim
jg61hawk is offline   Reply With Quote
Old 05-26-2022, 12:05 PM   #2
Bob C
Default Re: Towing Hook Up Question
You don't want to pull from the center of the axle, pull from close to the spring perch.
Bob C is online now   Reply With Quote
Old 05-26-2022, 01:16 PM   #3
Big hammer
Agree, also to tie down!
get a bigger hammer tap done
Old 05-26-2022, 02:32 PM   #4
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I have always had the flatbed tow trucks pull me up from the rear. This way when I got home, I could steer it off the tow truck and stop where needed.
Ivan in southeast va. is offline   Reply With Quote
Old 05-27-2022, 08:44 AM   #5
ronn
Had long haulers of russian decent tie down my rear by the spring......
result broken spring.
they stuck a 4 x 4 in between the frame and spring, to make the car look even and quickly left............
amateurs!
Old 05-27-2022, 09:06 AM   #6
mhsprecher
mhsprecher's Avatar
The Russians must have been accustomed to towing a GAZ.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 05-27-2022, 03:08 PM   #7
1931 flamingo
1931 flamingo's Avatar
I've had to have both the A and my 40 flatbedded. J-hook or bridal by the perches is the best way but a strap around the front axle (JMO) is OK. Most haulers now use "basket" straps over the tires now.
Don't forget to tip the driver.
Paul in CT
Old 05-28-2022, 01:33 PM   #8
Fred K OR
Put the toe around the front spring brackets.
Fred K OR is offline   Reply With Quote
Old 05-28-2022, 05:03 PM   #9
Bruce of MN
Bruce of MN's Avatar
I carry axle straps in the trunk to protect the no so good paint.
Old 05-29-2022, 11:19 AM   #10
trulyvintage
trulyvintage's Avatar
Lightbulb Re: Towing Hook Up Question
Hello Jim,
First off you should never flat tow a Model T.
You should trailer it or put it on a rollback
tow truck if you need it hauled.
Second - to winch a Model A onto or
into a trailer or rollback tow truck
you can use a nylon tow strap to
the rear axle near the center pumpkin
or at the front to either side of the center
of the axle.
You can safely fasten to the center
of the axle as well - if the Model A rolls
freely there is no danger of bending the axle.
The tow truck driver should have axle straps
and ratcheting nylon straps to safely tie down
your Model A to the rollback or trailer deck.
For transport in an enclosed trailer - I developed
this method of securing Model A and Model T
vehicles that I have used for several years:
@ https://youtu.be/hYTGYxw34Pc
Jim
trulyvintage is offline   Reply With Quote
Old 05-29-2022, 08:39 PM   #11
Synchro909
Synchro909's Avatar
Paul in CT
Tipping is not something that is done here. He is paid to do his job and that should be enough. If he doesn't like it, get another better paid job. That said, when I have given a tip it is often something like "Don't eat yellow snow."
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-30-2022, 01:13 PM   #12
trulyvintage
Thumbs up Re: Towing Hook Up Question
Paul in CT
Hi Paul
I always tip the rollback drivers I call out.
Usually $20 minimum.
Any good service should be acknowledged.
Jim
