Old 05-23-2022, 05:30 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Overheating Issue SOLVED!
Today I removed the reproduction 40 radiator from my 40 Tudor then removed the radiator from my 40 Coupe and put it in the Tudor. Took it on a 20 mile run and got into some stop and go traffic. Temp gauge never got above the Normal mark.
File Type: jpg 39C043A3-6EF8-41C5-914D-09E6C260A8A2.jpg (16.0 KB, 829 views)
Old 05-23-2022, 05:50 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Overheating Issue SOLVED!
Old 05-23-2022, 06:01 PM   #3
oldskool
oldskool's Avatar
glad you found the problem them radiators aren't cheap i was lucky to find a real nice original one for my 40 runs cool like yours maybe a little cooler as i added a shroud
oldskool is offline   Reply With Quote
Old 05-23-2022, 06:03 PM   #4
swoopNZ
MEMBER EMERITUS
Was your repro one from Drake - they look pretty good.
swoopNZ is offline   Reply With Quote
Old 05-23-2022, 06:28 PM   #5
Ken/Alabama
Yes it is , It looks great and fits great but it just will not cool. As we say here in the south,$850 up a Hogs azz !
Old 05-23-2022, 06:43 PM   #6
cadillac512
cadillac512's Avatar
Good job,Ken. Geez....I'd be a bit cross after spending the bucks for that sub-standard rad.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-23-2022, 08:15 PM   #7
cas3
That is quite a story. I wonder if somehow some of the tubes got plugged? When people make radiators, Drake or whoever, they all buy the generic cores from only a few places that make them. They are cut to size, then the headers and tanks installed that make them vehicle specific. Certainly the manufacturer could not survive sell expensive things that don't work, so I suspect there is something wrong with yours. I also suspect Drake will tell you to take a hike. Good you got it figured out.
Old 05-23-2022, 08:25 PM   #8
Ken/Alabama
Just so happens my cousin in law that I’ve known since first grade is operating his family’s radiator shop that’s been in business for over 100 years here. I’m gonna take it to him and let him see what’s going on with it .
Old 05-23-2022, 08:25 PM   #9
deuce_roadster
deuce_roadster's Avatar
I have a Drake radiator in my 40 coupe. Never gets above the calibration mark on the temp gauge (which I think is 170). Engine is not stock, 4" crank, Ross pistons, mild cam, Holley 4bbl with dual exhaust. Of course this is just 1 data point.
Old 05-23-2022, 10:21 PM   #10
Ken/Alabama
Wow, that’s great . Before I purchased that radiator I reached out for any reviews good or bad. The only reviews I seen ,and they were few, were good. Maybe I just got a bad one. Who knows ?
Old 05-23-2022, 10:37 PM   #11
tomcarman
tomcarman's Avatar
Sounds like you got a defective one? It would be interesting to somehow set it up vertically on say some saw horses and run water through it with a garden hose just to see if there is some internal blockage. Nonetheless it's great you're backup and running!
tomcarman is offline   Reply With Quote
Old 05-24-2022, 05:12 AM   #12
KiWinUS
KiWinUS's Avatar
Great to hear Ken.
Old 05-24-2022, 08:26 AM   #13
19Fordy
19Fordy's Avatar
Ken, That's great news.
PLEASE be sure to have your cousin take photos of what the interior of the DRAKE radiator looks like and what specifically caused the overheating.
Then contact DRAKE , let him know and ask for a refund or a least a credit.
Old 05-24-2022, 09:05 AM   #14
slowforty
slowforty's Avatar
Not to hijack this thread (too late) but i have a radiator that looks like a 40 radiator but is an inch larger all the way around with a shroud. anyone know what it is for? thanks
slowforty is offline   Reply With Quote
Old 05-24-2022, 09:15 AM   #15
oldskool
oldskool's Avatar
it maybe better to contact drake first and see what they say
Old 05-24-2022, 12:00 PM   #16
Flathead Fever
Flathead Fever's Avatar
Check the number of tubes and the size of the tubes and compare them to the original. I had one new radiator at work where they used so much solder it plugged the tops of the tubes. How could they not have seen that? If it was still in the car, you could have taken infrared thermometer and seen if some tubes are not getting hot, meaning they are plugged.
I had aftermarket Modal A radiator break the mounting bracket off of the radiator on the first road trip. It was half the thickness of the original. After that, no more repro radiators for me only, re-cored originals.
Old 05-24-2022, 12:40 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
They WILL likely say: "Wow, we have never heard that problem before."©
I believe they may hold the copyright on that phrase. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 05-24-2022, 04:09 PM   #18
Fritz
Fritz's Avatar
Big truck?
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 05-24-2022, 06:07 PM   #19
38convsedan
38convsedan's Avatar
I’ll bet that’s a relief!!!
38convsedan is offline   Reply With Quote
Old 05-24-2022, 06:41 PM   #20
Ken/Alabama
I did talk to the folks at Bob Drake today and explained the problem. They’re going to get back with me tomorrow.
