Old 04-10-2022, 09:27 AM   #1
Al Mack
Default Your painted front bumper
Looking for ideas (flat, satin or gloss . . . Black, Gray, Silver or ?) for painting my front bumper on a no-frills early-1931 Black pickup. The body, wire wheels, radiator shell, headlight buckets and the cowl band will also be Black.
Pictures and suggestions would be appreciated. Thanx.
Al Mack is offline   Reply With Quote
Old 04-10-2022, 09:53 AM   #2
Big hammer
Default Re: Your painted front bumper
Power coat near chrome! It looks good in the catalogs
get a bigger hammer tap done
Old 04-10-2022, 09:56 AM   #3
katy
katy's Avatar
The front bumper bars on my '31 ccpu are painted (looks to me to be) semi-gloss silver. (came to me that way.)
Also the bars are straight and methinks that the ends should be bent slightly to the rear.
Old 04-10-2022, 10:42 AM   #4
Keith True
Keith True's Avatar
I had a set of bars powdercoated with the almost chrome a few years ago.Way better than I was expecting.It looks like aged chrome.Looks nice on the pickup,and has a warm look,like nickel.I did 100% of the prep work,including a phosphate wash and devising hooks to hang them by.I put some lead concrete anchors in the end holes,and screwed eyebolts into them.The powder guy took them from me,hung them up,sprayed them,and ran them into the oven.He charged me $100.but had to do zero prep.
Keith True is online now   Reply With Quote
Old 04-10-2022, 11:51 AM   #5
Russ/40
Russ/40's Avatar
Personally, as much as i love black, not so on a bumper. I'd go silver or the powder chrome. You did not state your car's theme, original or hotrod, so i'm assuming original as to my preference.
Old 04-10-2022, 12:21 PM   #6
Cape Codder
Cape Codder's Avatar
katy- Me thinks you have '28 bumpers if they are straight and open on the ends!
Cape Codder is offline   Reply With Quote
Old 04-10-2022, 12:36 PM   #7
Marshall V. Daut
Wide chrome tape looks very good if carefully applied and smoothed out with a squeegee. Trim and fold the excess width just barely over the edges of the bumper bar. The bumper bar surface must be very smooth with no deep pits or missing metal chunks, otherwise the tape will conform to these depressions and ruin the smooth finish. Spray the backside of the bumper with aluminum or cadmium paint. You might be surprised how good chrome tape looks on Model A bumpers, certainly eons above spraying the bars with paint. The tape won't fool anyone into thinking the bars are plated, but it does look pretty decent.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 04-10-2022, 01:05 PM   #8
Charlie Stephens
I would paint it black to go with the other black items. You could almost believe it came that way from the factory.
Charlie Stephens
Old 04-10-2022, 01:19 PM   #9
1931 flamingo
1931 flamingo's Avatar
My A had painted bumpers when I got it. A gloss black. No one called me out on it in the 9 years I had it.
Paul in CT
Old 04-10-2022, 02:33 PM   #10
ndnchf
ndnchf's Avatar
My all black early '31. I like it plain Jane, but the bumpers give it just a touch of bright. Eventually I'll get black headlamp buckets and radiator shell.
ndnchf is offline   Reply With Quote
Old 04-10-2022, 05:56 PM   #11
GRutter
GRutter's Avatar
Gloss black looks almost factory on a truck
GRutter is offline   Reply With Quote
Old 04-11-2022, 10:57 AM   #12
katy
katy's Avatar
They're straight, but not open on the ends. BTW, this vehicle is a conglomeration of parts by the PO.
Old 04-11-2022, 06:48 PM   #13
burner31
burner31's Avatar
Post 5 states it better then I can, but I would add that they look good for several years, and when they don't?...You just sand them down and spray them again...easy, quick and you're good to go... (just let it dry COMPLETELY)
Keith
Shawnee OK
'31 SW 160-B
