Old 04-04-2022, 03:57 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Modern steel belted radials on '37 wide five wheels
Originally Posted by farmertom View Post
Hey use guys, are '37 wide five wheels welded or rivited. I assume a tire dealer that also does agricultural tires would have correct size valve stems to fit my rims if going with tubeless radials. Tom.
The 'wide-fives' each have 12 rivets, as can be seen clearly in the third & fourth wheels from left....all are wide-fives. The second picture clearly shows the size of the hole for the valve stem. As I said earlier, I simply bead-blast the inside of wheel (where the air goes), and dab a little JB WELD around each rivet. Coop
Click Links Below __
T5 W/TORQUE TUBE
