after reading thread for wide five rims and dyna beads,need input on anybody running modern steel belted radials on wide fives. is it safe to,will they walk off rim in turns,can you run without tubes? my wide white bias ply do have some age to them tread is still very good and all are just getting dry i think were mounted in 2014 and are in pretty good shape i'm just thinking of making a change.most modern radials in 16" are light truck tires iv'e heard 215 85R 16 or 195 85R 16 will work. thanks for input,Tom.
I'm running Coker Excelsior radials on my 32 . . . which were kind of designed to have the look of bias ply tires, with the great improvements of modern tire technology. I'm running them on old wire wheels, so I am running tubes. In every car I've had where I switched from bias ply to radials (variety of brands), I've been super happy with the results. You'll find your car will track a lot better, will handle better, will brake better, will be better in the rain . . . every single aspect is better - period.
Thanks bored&stroked. i was wondering whats barners thoughts on using just modern radials that can be purchased locally actually are light truck replacements 215 85R 16. Do the mounting beads differ from those tires like yours made by coker. i dont care that they dont have the old bias ply look.I will probly go with black walls anyway. Tom
I am in the process of upgrading the tires on my '36 to Coker Classic 600 x 16 (16" Bias Profile Radials) w/ Coker 16" tubes. My wheels are stock 5 on 10 16" that I had checked for truness and powder-coated...
Radial tires are high pressure, therefore if you under-inflate them, you will scuff the shoulders off of the tires, I generally run 34 lbs in the tires on my older cars. I have radial tires on several old cars, '39 conv. 38 Buick '53 Olds 88 and a '56 T-bird. Chrysler went to a safety, beaded wheel in 1941 on Chrysler/DeSoto's, GM did not until the '70's except on the '51 and later Century's and Roadmasters. Generally it is a myth about tubeless tires walking off of the rim, if they are kept properly inflated. I am using tubes in the 600 x16 Coker's because the sales rep suggested that I do so because of the riveted rims in lieu of welded.
Bill.... 36 5 win cpe |
36 side view.jpgWhat blucar said
i have 185/75/16 on my 37 coupe with tubes. they work fine
#8 | |
Man, Thats a nice lookin coupe !
hi 39deluxcp fellow iowan,do run those 185/75/16 radials on oe wide five rims and would it be safe to run without tubes? and where did you purchase the tires.
I had Diamond Back 6.00 R 16 installed - no tubes - 40 lbs pressure last June. So far so good.
I have 215 85r 16s on my woodie wagon. They are pretty tall and skinny and that's the look I like. You get a bit of 'rubber overdrive'. I would think they equate to 7.00 x 16 truck tires and a 235 85r 16 is the same as the old 7.50 x 16, which was the standard 3/4 ton pickup tire for many years. I run 32 lbs in mine and have run them tubeless for a couple of years without issues. Steering is waaaay beter than when I ran bias ply.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#13 |
The wide 5 "artillery" wheels have so many rivets I believe you would have to have some pretty nice original wheels to not have a slow leak some where. I recently went tubeless on my 52 willys army jeep. I had very good, not rusty, original wheels. I had them sand blasted, then while they were naked I brushed epoxy primer around each rivet to make sure it got good penetration , then after spraying the whole wheel with epoxy I went around each rivet with silly cone, and used a rim lube to mount and seal the beads, and....no leaks after a year.
#14 |
I'm being a bit cheeky, but what about some flexseal or some other modern coating too.
#15 | |
#16 | |
#17 |
I agree, they are overkill. Mine are load range E. They came on many dualie pickups as standared equipment. I bought mine at a used tire place for 25 bucks each and they are 'knee deep' in rubber. I bought all six and they match. The woodie built on a pickup chassis is a pretty heavy vehicle and I drive at 40 mph and slower so I mounted them myself on my manual tire changer and didn't balance. The beads would be perfect in them I bet.
#18 |
Hey use guys, are '37 wide five wheels welded or rivited. I assume a tire dealer that also does agricultural tires would have correct size valve stems to fit my rims if going with tubeless radials. Tom.
#19 | |
Beads would probably be a better solution. |
#20 |
ben running diamond back 600x16 equivalent for over 30,000 mi with no issues. many 700mi trips in hot weather and don't leak. balance them with adapter from speedway.
37Don |
