Old 03-07-2022, 11:57 PM   #541
mercman from oz
mercman from oz's Avatar
Default Re: Two-Door Ford and Mercury Wagons
1956 Ford Customline Two Door Wagon
Old 03-10-2022, 04:16 AM   #542
mercman from oz
1956 Ford Park Lane Wagon with different Grille Insert
Old 03-10-2022, 08:55 PM   #543
paul2748
paul2748's Avatar
Looks like the headlights were also modified. If I remember correctly, early Olds?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-11-2022, 06:55 AM   #544
KULTULZ
KULTULZ's Avatar
Unhappy Re: Two-Door Ford and Mercury Wagons
If you think this is bad -
Look at this -
KULTULZ is offline   Reply With Quote
Old 03-11-2022, 08:10 AM   #545
KULTULZ
KULTULZ's Avatar
Arrow Re: Two-Door Ford and Mercury Wagons
Originally Posted by mercman from oz View Post
1957 mercury voyager or commuter? 2 door station wagon
NEED PATENT PLATE INFO -
Old 03-11-2022, 08:51 PM   #546
mercman from oz
Imported 1956 Ford Two Door Wagon that now calls Australia home.
Old 03-13-2022, 11:33 AM   #547
58Yeoman
58Yeoman's Avatar
That '58 wagon with the fender wells cut out is looking pretty good about now.
https://tinyurl.com/4zpjph57
58Yeoman is offline   Reply With Quote
Old 03-13-2022, 05:06 PM   #548
mercman from oz
Pair of 1958 Ford Two Door Ranch Wagons - 58Yeoman
Old 03-15-2022, 05:11 PM   #549
mercman from oz
Neat 1956 Ford Mainline Two-Door Ranch Wagon
Old 03-18-2022, 04:09 AM   #550
mercman from oz
1955 Ford Fairlane "Parklane" Station Wagon, a year before they were offered by Ford.
Old 03-18-2022, 05:04 PM   #551
5851a
On the 58 wagons the tail gate tail lamp lenses were slightly shorter than the outers to keep them from breaking when tailgate was down. http://www.oldcarbrochures.com/stati...rochure-06.jpg. I think the inner bulbs were 1156 and outer 1157.
5851a is offline   Reply With Quote
Old 03-18-2022, 05:59 PM   #552
mercman from oz
1958 Ford Wagon Brochure - 5851a
Old 03-18-2022, 06:05 PM   #553
mercman from oz
In this photo from the original Sales Brochure, all 4 Tail Light Lenses seem to be the same length?
5851a suggested that the Inner Ones were shorter?
Old 03-18-2022, 08:34 PM   #554
5851a
Maybe only 1/4 inch as original. Dimensions except depth were the same, I don't have parts book that goes back that far for the numbers. Only the wagons were shorter. Hope someone with a parts book or Hollander interchange manual can provide information other than from old memory.
Old 03-19-2022, 12:47 AM   #555
mercman from oz
For what ever reason, no "true" 1957 or 1958 "big" Fords were sold in Australia during these two years. For 1957, Ford Australia added 1956 Ford Fairlane Trim and called the car a 1957 model. For 1958, our 1958 Fords wore a 1955 Meteor Grille with 1956 Meteor Side Trim.
On that basis, I don't know too much about the regular 1957 and 1958 Fords, as the only ones that I have seen are recent imports, and even they are rare here.
Old 03-20-2022, 03:50 AM   #556
KULTULZ
KULTULZ's Avatar
Actually, the T/G LAMPS were longer (incl body) (same lens - inner and outer) to accommodate the optional backup lamps -
Old 03-20-2022, 05:23 PM   #557
5851a
So the short one I bought wasn't for a wagon? Ford mechanic told it was a for a wagon since long one would break so I exchanged. Was is possible they had short ones included with Continental kit and that's what I had?
Old 03-20-2022, 09:11 PM   #558
KULTULZ
KULTULZ's Avatar
You are working on a SW? The width would not factor as the gate would (should) stop before hitting rear face bar.
By CONT KIT, you are referring to sedan, correct? That would have no bearing on the inner lamp door length.
Below are TEXT DESC of both PN's 13448 and 13434. Use them (w BODY CODE) w ILL posted in above post.
Make sure I answered that correctly ...
Old 03-20-2022, 10:26 PM   #559
mercman from oz
1958 Ford Station Wagon and Sedan Tail Light Clusters compared. Looking at these two pictures, the Sedan Tail Light Cluster looks longer than the ones on the Station Wagon?
Old 03-20-2022, 10:28 PM   #560
mercman from oz
1958 Ford Two Door Ranch Wagon - KULTULZ
