Old 02-05-2022, 01:18 PM   #1
Veeder
Default 41 v8 lower radiator hose
Sad I’m asking this but….
I’m replacing 1 of the lower radiator hoses and as you know they are S shaped. One end of the hose has about a 1 inch longer piece of pipe then the other. Depending on which way I place it it puts the hose just about touching the torsion bar or the other way it puts it within an inch of the fan blade.
Is there a right way that this hose should be installed or is this just a fluke??
Veeder is offline   Reply With Quote
Old 02-05-2022, 06:21 PM   #2
oldskool
oldskool's Avatar
Default Re: 41 v8 lower radiator hose
i just replaced mine on 1940 the long end goes on bottom if the top touches the torsion bar just dont put it too far on the water pump outlet,i put a heater hose nipple on mine what a pain in the butt
oldskool is offline   Reply With Quote
Old 02-05-2022, 07:11 PM   #3
Kube
Super Moderator
Kube's Avatar
These hoses were reproduced using earlier (1939) service parts. They are not accurate for 1940 - 1941 Fords with an authentic sway bar.
You will need to trim them to clear the sway bar. If I recall correctly (oh oh), it only requires about 3/4" to be removed from one end.
Kube is online now   Reply With Quote
Old 02-05-2022, 07:12 PM   #4
Veeder
Oldskool thanks .. As for the heater core hose I took a short piece of tubing had the fitting welded to it. All I do now when that hose needs to be replaced is cut the hose in the center removing approx an inch and clamp the insert into the middle of the new hose. I’m done messing with that fitting.
Old 02-05-2022, 07:14 PM   #5
Veeder
Thks guys I’ll cut 1/2 inch off I almost did that
Old 02-05-2022, 08:14 PM   #6
Lawson Cox
Lawson Cox's Avatar
Sort of like performing a bris
Old 02-05-2022, 08:25 PM   #7
mercman from oz
mercman from oz's Avatar
1941 Mercury Radiator
Old 02-05-2022, 10:51 PM   #8
cadillac512
cadillac512's Avatar
Mercman, I have that '41 Merc radiator in my car and cannot find lower hoses to fit. It's an odd thing, different from '41 Fords.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 02-05-2022, 10:56 PM   #9
mercman from oz
cadillac512, Sorry that I cannot help. I took that photo of my mates 1941 Mercury Radiator when it was out for cleaning. Regards Mercman <><
Old 02-06-2022, 07:37 AM   #10
Veeder
A question on the pic of the “41 Merc” radiator?? Just for those who may be purists in restorations didn’t it have a split core? My 41 did but it was to expensive to get it recored as original
Old 02-06-2022, 09:09 AM   #11
cadillac512
I believe so. Mine has been recored as well and no longer has the split, but the car does have the hole for a crank and the nut for the crank to engage.
Terry
Old 02-06-2022, 12:51 PM   #12
rotorwrench
rotorwrench's Avatar
The split core was more expensive to recore even back in the day. It would be even more expensive now since it would require a wide core to be cut in two. A pretty big expense just to allow for use of a hand crank. Purists have no choice.
Old 02-06-2022, 04:51 PM   #13
mercman from oz
1941 Ford Radiator showing the bottom Hoses
Old 02-06-2022, 05:12 PM   #14
oldskool
oldskool's Avatar
i dont follow you what kind of fitting are you using? i have the standard one that most dealers sell
Old 02-06-2022, 07:03 PM   #15
Veeder
I’ll find a pic of the fitting I made n a bit
Old 02-06-2022, 07:38 PM   #16
Veeder
Here is the pic —-approx 2” stainless steel with a brass nipple welded to it for attaching to the heater hose. The hose I just cut at the halfway point removed approx 1 inch and clamped it in place.
File Type: jpeg 4157DA2B-CB31-470B-A9B4-28E59E8C9EEB.jpeg (26.5 KB, 63 views)
Old 02-07-2022, 07:51 AM   #17
oldskool
oldskool's Avatar
thanks great idea
Old 03-23-2026, 03:00 PM   #18
squirefd
The early 41 Mercury radiator may have had the split but the late ones did not.
squirefd is offline   Reply With Quote
