#15 |
After you get your 3 or 4 carb intake alll set up and ready to go. You'll have to replace the distributor sa well. The 8ba dist won't work right, it needs one special carb.
You could however, run a 3 duce intake with the proper carb in the middle and dunnies on each end and nobody would know the difference. Works like a Cheam $$$$$$$ Gramps |
