Folks,
8BA engine compression test indicate No.3 = 98 psi, No.8 = 79 psi. When adding a drop or two of oil to these cylinders they rise to around 112 psi. All other cylinders hover around 112 - 115 psi when dry. Engine starts with a couple of squirts from the throttle and a push of the button. Engine oil pressure at cold idle 30 psi - hot idle 15 psi. Is it worth the effort to replace the piston rings? Have never done a flathead before. Thanks for any advice. |
If it ain't broke, don't fix it. Sounds good to me. What concerns you?.
I agree with Lawson. I drove my '51 for 25 years with an engine that had 85-90 psi in all of the cylinders. It got me around fine. Most ordinary guys would kill for compression numbers like that.
Has the engine been sitting a while? If so a little "treatment" (MMO, Sea-Foam, etc.) might make everything right. |
If it is running good then I agree with the others and don't do anyting at all. Just drive it and enjoy. What I would do is occasionally redo the compression test and monitor it.
then if it is still low do a leakdown test if you are still worried. How evenly does it pull from low rpm (10 mph) in top gear? |
Just drive it and enjoy it.
Like others, I would drive as is and enjoy it. Summer is just around the corner. Seafoam and MMO are your friends if it has spent a lot of time sitting and has some stuck rings and sticking valves.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
those numbers are magic seen worse numbers run perfectly fine soak the cylinders in a little light oil [mmo or such] for a week clear the cylinders and take for a good run and vary the load and eng speed if it runs fine keep on going down the road. A little 2 stroke oil in the fuel helps as well about the amount you would use in a gallon to a tank and dont be frightened to use regularly as no eng likes sitting idle
Drive it . Enjoy . If you get into it ,itll end up being a complete rebuild . I say this cause youll see something else is out of spec and youll be looking at $2000-3000 plus a long downtime.
waynet, you mentioned "spit back" in the carburator. That could blow your power valve. You may have a valve sticking at times letting it spit back. Some MMO may help that.
#13 |
A leak down tester is the only way to truly know what the engines internal condition is.
Using the leak down tester you can easily determine the condition of the piston rings and easily determine how well the intake valve is seating and how well the exhaust valve is seating. The compression gauge was a handy way of checking a cylinder many years ago and of course for those who have one its the way to test now however being the 21st century there is a better way. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#14 |
This is exactly why I haven’t done a compression test. ‘Cause if I knew it would gnaw on me and I’d have to fix it! As is it runs fine. The transmission however is gnawing on me. It’s noisy and when slowing down pops out of 2nd gear.
Cheers, Jim&Sandy McGregor, IA |
#15 |
If it didn't pop outa second gear it would a chevy. Ick.
#16 |
waynet: Based on info. you have provided, I would say "don't take it apart".
Drive it and enjoy it. |
#17 |
I second and third MMO in the gas tank and dribble some in the carb till it smokes. I have an injector in my 46 that feeds MMO into the carb. Great stuff. John |
#18 | |
#19 |
I didn't think of that mfirth. I assumed the cause would be poor carburetor settings/jets or bad ignition timing. It only happens when I floor the throttle at low revs in any gear. Thanks for your input.
#20 |
Lugging an engine (too much load at low engine speed) will cause rough running like waynet described, that is normal. I am guessing that mfirth is warning you that intentionally making your engine pop back through the intake is hazardous to the power valve in the carburetor.
