Old 01-11-2022, 06:17 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default Any demand for 3 3/4 8BA cranks
I know they are too heavy to ship, but I put a 4 inch mercury crank in my 8BA. I have no use for the 3 3/4, 20 under I think. Should I try to sell it locally or let it go to the scrapper?
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 01-11-2022, 06:39 PM   #2
Krylon32
Default Re: Any demand for 3 3/4 8BA cranks
I had a NOS French 3 3/4 crank and finally got 400.00 out of it. Forgot I had to throw in 8 new 8BA rods.
Krylon32 is offline   Reply With Quote
Old 01-11-2022, 07:18 PM   #3
bobH
My local flathead machine shop/rebuilder has offered these for free. 'Course, this was at least five years ago.
bobH is offline   Reply With Quote
Old 01-11-2022, 07:38 PM   #4
Tim Ayers
At guy at Hershey had twelve 3 3/4" cranks as tent weights. When I asked him about it, he said, "What the hell else am I going to do with them?"
I got a chuckle out of that.
Old 01-11-2022, 07:58 PM   #5
Kube
Super Moderator
Kube's Avatar
Scrap
Old 01-11-2022, 08:58 PM   #6
tubman
tubman's Avatar
I have one good 8BA crankshaft "under the stairs" in my shop; well, just because I wouldn't want to be in the position where I didn't have one available.
Old 01-11-2022, 10:53 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
What the heck would be wrong with making a standing offer, FREE of charge, to anyone who might need one? I mean .....if you're willing to toss it anyway.....! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-11-2022, 11:47 PM   #8
Newc
Newc's Avatar
They are perfect for a loow buck $ engine. Used parts thru out or someone planning on high rpms- Ron will tell us. Newc
Old 01-12-2022, 07:36 AM   #9
RBRanche
I'm by far a expert on flatheads but seems to me a guy could offset grind a 3 3/4 crank to come close to the same stroke as a mercury crank and use early rods. Giving the price and availability of merc cranks, is this an option that's been explored?
RBRanche is offline   Reply With Quote
Old 01-12-2022, 07:44 AM   #10
Mart
Mart's Avatar
Good for use in a low buck rebuild of a 59A. Use with the 8BA rods to use the cheaper later bearings.
Old 01-12-2022, 08:02 AM   #11
Tim Ayers
I have not purchased pistons for an 3 3/4" offset ground crank, but I'd think those would be a special order piston due to wrist pin height. Add that to the cost of the machine work, I would think you would be at or over the cost of finding a 4" crank.
That was the trick prior to Ford making the 4" crank. I think that fell out of favor once 4" cranks were readily available.
Old 01-12-2022, 08:10 AM   #12
mfirth
I'm with V8COOPMAN & Mart. Keep or give to someone. Mount it on the wall as "art"......
mfirth is offline   Reply With Quote
Old 01-12-2022, 08:17 AM   #13
alanwoodieman
I use them to convert 59a blocks and even an A block can be converted , I pull the sleeves bore to 239 standard piston use the 19a rear seal adapter and get a good running original looking 29 to 41 engine
Old 01-12-2022, 09:44 AM   #14
Kube
Super Moderator
Kube's Avatar
I did make this type of offer on cranks, cams, radiators, starters, generators, etc. NO takers.
I did have a few folks suggest that if I shipped them for free, they'd take them.
Old 01-12-2022, 10:05 AM   #15
1937sedandelivery
don't know how to post actual picture....
1937sedandelivery is offline   Reply With Quote
Old 01-12-2022, 10:29 AM   #16
19Fordy
19Fordy's Avatar
1937: Neat idea. When you get time, paint your mailbox crankshaft black.
Old 01-12-2022, 01:03 PM   #17
tubman
tubman's Avatar
Actually, that not a flathead crankshaft because they are too short for this actual purpose.
Straight eight cranks are best.
Old 01-12-2022, 01:59 PM   #18
petehoovie
petehoovie's Avatar
Old 01-12-2022, 03:33 PM   #19
Alaska Jim
Alaska Jim's Avatar
My brother had one ground to 3 7/8 several years ago. still has not used it, and does not know if he ever will.
Alaska Jim is offline   Reply With Quote
Old 01-12-2022, 05:48 PM   #20
Ronnieroadster
Ronnieroadster's Avatar
There had been some racing organizations in the mid west that allowed the Ford crank to be offset ground so pistons were once available for this purpose. The 3 -3/4 crank would end up becoming 3-7/8 stroke. The problem with this today is that a custom set of pistons needs to be made for this odd offset so this would pretty much eliminate any value to the idea.
As for giving away the Ford cranks to anyone wanting one for free its great for a local give away where its picked up in person. The game changer is the shipping cost for that free crank its going to be very expensive. Shipping would be a couple hundred dollars easily.
Considering how frugal most barn member's are I don't see any cranks being shipped.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
