My engine has a ticking noise that increases with rpm and can be heard at idle when stopped. I think it is a valve clearance noise. If it is valve noise is it normal? I have heard it on some other A's but not all. Thanks, Bill G
Try to locate the noise. If its coming from the valve cover its probably valve lash. Removing the cover will allow for checking the lash and determining if you have non-adjustable or adjustable lifters. [ manifolds don't have to be removed for this.]
Is the noise normal ? Yep, that is, a certain amount is normal. |
You might also want to check your timing gear. Mine started making a slight noise before it let go….
Sometimes a valve will start sticking in these engines due to varnish from old fuel because the spring tensions are very low compared to an overhead valve engine doesn't take much for the valve to stick
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Please don’t start taking things apart.
Marvel Mystery Oil in your gas should help you out. If you have a higher mileage engine you might also want to change your old to 20W-50 along with one blue bottle of STP as the last half quart. This is my standard first advise on what you have said your car is doing. In most cases that I am aware of, it has done the trick. Good luck. Enjoy. |
Buy a mechanics stethoscope and see if you can narrow it down a bit as to where it is coming from.
Dave / Lincoln Nebraska |
My ticking noise turned out to be a blown manifold gasket
I will check these things this weekend. Thanks
