Is there an 6 volt electric fuel pump with the right PSI on the market. Seem's like the only ones I see are 12 volt.(2-5psi)
This was discussed a little while ago
https://www.fordbarn.com/forum/showt...tric+fuel+pump My pump is turned on with a spring loaded switch and I use it for priming only, it was installed by the previous owner. I’m not sure what brand it is but it is 6 volt. |
Airtex 6 volt at Rock Auto is around the cheapest so far
Airtex E8902
