Old 10-29-2021, 04:02 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default LED brake lights update
I have decided to just stick with incandescent bulbs for brake lights. WAY TOO MUCH HASSLE.
I ordered what I thought was the correct bulbs, but they were double contact.
I then ordered the single contact bulb, which is what I need for my 35. Single contact bulbs arrived but didn't work. I ordered replacements, and they didn't work either. 4 bulbs in a row couldn't be bad, or could they?
I called Steiner and the tech guy said to run another ground to the socket on the single contact bulbs with alligator clips, that the double contact was providing the ground. I did that at several locations. No help.
For what it's worth, the double contact bulbs DO WORK. Other single contact bulbs, both LED and incandescent, work fine so it ain't the ground to the socket.
SUGGESTIONS? I'm about to lose my religion.
Old 10-29-2021, 10:10 PM   #2
Eagle43
Default Re: LED brake lights update
If you have positive ground, your problem may be current direction. LEDs are diodes so they allow current to go only go in only one direction.
Eagle43 is offline   Reply With Quote
Old 10-29-2021, 10:50 PM   #3
petehoovie
petehoovie's Avatar
Yup! Polarity sensitive....
Old 10-30-2021, 02:57 PM   #4
Lawson Cox
Lawson Cox's Avatar
Never thought of that, and apparently neither did the tech guy. I'll check with Steiner tech guy again. I think they show this bulb to NOT be polarity sensitive. HOWEVER, I'm gonna stick with the way Henry built it on these bulbs.
Thanks Pete and Eagle43. (As you can probably tell, I flunked High School "Radio and electricity".
Old 10-30-2021, 03:31 PM   #5
petehoovie
petehoovie's Avatar
Lawson, you should be able to check to see if the bulb is polarity sensitive with and ohm meter. Continuity (short), as seen on the meter in one direction, reverse the leads of the meter and no continuity (open).
But yeah, just "stick with the way Henry built it." Paint the inside reflectors white....
Old 04-02-2022, 12:22 AM   #6
Eagle43
I found some 6 Volt positive ground LED bulbs on AliExpress. They have both 1156s and 1157s in amber, red and white. They sell for about $5 each including shipping from China and they are super bright. I'm using amber for the front (clear lenses) and white on the back (red lenses) on my 1952 F1. They also sell 6 Volt negative ground bulbs and I've just ordered some for my 1926 Chevy and my 1929 Whippet.
Old 04-02-2022, 07:11 AM   #7
Terry,OH
Terry,OH's Avatar
Most of the tail lights I have seen, except 32, use one light bulb, with a double contact. One contact is for the running tail light and the second is for the brake light. Both contacts use the shell of the bulb as common ground.
Terry,OH is online now   Reply With Quote
Old 04-02-2022, 07:17 AM   #8
slowforty
I like Marts' idea of putting a chrome or silver cupcake liner behind the bulb. Cheap and effective.
slowforty is offline   Reply With Quote
Old 04-02-2022, 08:20 AM   #9
Veeder
I actually took apart an LED light bulb designed to work in the 4 volt ranges.
1) the are polarity specific meaning neg ground
2) they have a current limiting resistor in series with the LED (not all led bulbs will necessarily have the current limiting resistor but I would expect most will)
3 I hope too come up with an easy option to modify dash lighting with bright leds so I’ll let you guys know if I’m successful
Bob
Veeder is offline   Reply With Quote
Old 04-02-2022, 09:00 AM   #10
farmertom
farmertom's Avatar
Me too on the cup cake liners in tail lights in my '37. fit perfect in tail light bucket.concentrates and facites the light. Tom.
farmertom is offline   Reply With Quote
Old 04-02-2022, 10:32 AM   #11
mfirth
I tied some inmy 52 Vic, didn't work 4 me either. Put a 3rd light in the back window, it got attention.
mfirth is offline   Reply With Quote
Old 04-02-2022, 11:21 AM   #12
farmertom
farmertom's Avatar
Yep,also like mfirth i used the led brakelighter kit in my '37. it really does work for most distracted idiots.
Old 04-02-2022, 10:07 PM   #13
Eagle43
Almost all the LED light bulbs offered for sale are negative ground which almost all cars use. For the "positive ground" Fords you need to buy LEDs that are specifically sold as "positive ground" or they won't work. LEDs are the way to go if you can since they produce a lot more light and a lot less heat and use less amps.
Old 04-02-2022, 11:35 PM   #14
rich b
rich b's Avatar
What kind of tail lights? '35 should be a dual contact bulb.
Old 04-03-2022, 02:59 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
Agree with you, Rich! There's no telling what he has pieced-together. It's going on that pick-up in his avatar. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-03-2022, 05:09 AM   #16
fortyfords
fortyfords's Avatar
My two cents, white reflects better than the chrome or silver reflectors. If you think about it, what do all building lights have for background, white. I make my cupcake reflectors out of white paper.
fortyfords is offline   Reply With Quote
Old 04-03-2022, 07:23 AM   #17
Ronnie
Ronnie's Avatar
https://www.ledlight.com/6-volt-posi...ed-lights.aspx
These guy's have you covered
R
Ronnie is offline   Reply With Quote
Old 04-03-2022, 10:32 AM   #18
farmertom
farmertom's Avatar
yo,fortyfords, why i use reynolds bright shiny cup cake liners unlike building lighting which have white back round they in turn do not have to project the light through a thick red lens. all automotive tail lights have either a pillowed,or mirrored reflector. respecfully, Tom.
Old 04-03-2022, 09:06 PM   #19
Ken/Alabama
Ken/Alabama's Avatar
Got 6 volt LEDs in my 40. Taillights,license plate light ,parking lights,dash lights & dome lights.
File Type: jpg C5361B47-AD9C-4A32-9F95-578DE43FB709.jpg (20.7 KB, 22 views)
File Type: jpeg C30C60FB-01E8-4855-B96B-7706C9A3B2DC.jpeg (59.9 KB, 25 views)
Old 04-04-2022, 05:34 AM   #20
Veeder
Ronnie
Thks for the link ordered 4 dash lights and 2 rear lights fiqured I would give them a shot will let you know but based on the description they should
