Old 10-19-2021, 12:51 AM   #1
deuce lover
deuce lover's Avatar
Default French Flathead in the womb
Here it is still in the Military "Cargo"from mid 1950's. The seller wants 950 Euros(about $1100) for it.Its not the one that most are looking for that use the 8BA heads. These are like the 59A.Notice the location of the dist. Pete or Mercman please enlarge.Thanks
Old 10-19-2021, 01:12 AM   #2
petehoovie
petehoovie's Avatar
Default Re: French Flathead
Old 10-19-2021, 01:13 AM   #3
mercman from oz
mercman from oz's Avatar
French Flathead by deuce lover
Old 10-19-2021, 02:26 AM   #4
deuce lover
Thanks to you both !!
Old 10-19-2021, 05:53 AM   #5
Tim Ayers
Can you remove the stock distributor and run a crab or helmet off the cam like Ford? I see a block off plate on the front cover. I never knew they made two types.
Old 10-19-2021, 06:18 AM   #6
Mart
Mart's Avatar
I had a German engine with that same distributor position and the block off plate. I removed the plate and ran a helmet on it, then switched to a crab type. Cam was long nose type.
Old 10-19-2021, 06:54 AM   #7
rockfla
rockfla's Avatar
Default Re: French Flathead in the womb
Thanks for sharing Sheldon. Cool stuff.......Excuse my ignorance but where or how is the distributor being run?
rockfla is online now   Reply With Quote
Old 10-19-2021, 06:57 AM   #8
alanwoodieman
back of cam, like the oil pump
Old 10-19-2021, 07:03 AM   #9
rockfla
rockfla's Avatar
SO is it through the hole where one would normally put the oil pressure sending unit?? OR is there an access hole in the back of the block???
Old 10-19-2021, 07:57 AM   #10
KiWinUS
KiWinUS's Avatar
Typically a governor in that location on French engines where this distributor is.
Old 10-19-2021, 08:27 AM   #11
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Could you please elaborate as to what type of vehicle (Military "Cargo") this is?
Thanks,
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 10-19-2021, 08:35 AM   #12
deuce lover
The "Cargo's were 1955-63 made by Simca.They are equivalent to the "Deuce and 1/2 trucks we had in the army.I have a friend sending me pics which I will post. Those engines were 3.9 litre.The later "Marmon" were 4.2 litre with the 4" crank. I happen to have a Metric 97 (marked 24.6)that came off a cargo engine.I put a USA 97 base on it.The aluminum oil pan in last 2 pics are off a Cargo engine.See pics.
First pic is of the Cargo. 2nd pic is of the Marmon.Pete please enlarge.Very last pic is of the 1956 "Cargo".Thanks
File Type: jpg JH9-36ywk774PiJ6ahw6yZPXJ4g7u34YI0oN9q9RUE56_YXz3wwDlbFs_VTqTLEiiioRHuSw_Vo7xL-ftAozibXaaxafg6Pd.jpg (57.5 KB, 238 views)
Old 10-19-2021, 10:09 AM   #13
Yoyodyne
Yoyodyne's Avatar
I guess this is a good place to post these I took at Hershey.
Yoyodyne is offline   Reply With Quote
Old 10-19-2021, 12:32 PM   #14
petehoovie
petehoovie's Avatar
Old 10-19-2021, 12:39 PM   #15
petehoovie
petehoovie's Avatar
Old 10-19-2021, 01:12 PM   #16
Tim Ayers
I have one of the French 4" cranks. I wish I had one of those oil pans. They looks cool.
Old 10-19-2021, 01:25 PM   #17
petehoovie
petehoovie's Avatar
Old 10-19-2021, 02:12 PM   #18
miwi
miwi's Avatar
On German flatheads the dissy was located at the rear of the engine. SO it seems that this one is not a french it should be a german G29 enigne
miwi is offline   Reply With Quote
Old 10-19-2021, 03:50 PM   #19
KiWinUS
KiWinUS's Avatar
Agree Tim. Nice oil pan. I believe you need this engine.
Old 10-19-2021, 03:54 PM   #20
Tim Ayers
Originally Posted by kiwinus View Post
agree tim. Nice oil pan. I believe you need this engine.
ttt
