10-13-2021, 02:55 PM | #1 |
Banger posi traction
So down at Jersey shore it looked to me that some of the A’s looked like they have Posi traction .
How’s that accomplice (weld the gears) Any one done this to a model A rear banjo . Looked to me some of those old model A’s hooked up pretty good with both wheels spinning in the sand .
"I can't cry as long as I know the Lord has risen " |
10-13-2021, 03:43 PM | #2 |
Re: Banger posi traction
I think you need to change to a 9" rear end. Once that's done, there are multiple LSD options such as TrueTrac or Trac-Lok.
10-13-2021, 04:59 PM | #3 |
Here is my story about welding up the spider gears. When I moved to the Santa Cruz Mountains in the late 1970's, I met some people who were logging redwoods. They had actually stopped logging at that time but the old equipment was still there. They had a 10 wheel truck with mud tires that they used to haul logs up the steep muddy trails to the loading site. They had welded up the differentials solid in both rear driving axles. They did not have to worry about going around corners because it was so muddy that the tires would just slip. The truck was 1950 vintage or older. The front axle may have been driving too. I don't remember. The truck may have been WWII surplus.
10-13-2021, 05:54 PM | #4 |
I've welded up side gears, mostly for myself. I was only interested in going in a straight line. The whole car will argue trying to go around a corner. It was a bit of a relief when I could spring for a locker. You can feel it ratchet but they will corner.
I can't remember any limited slip type rear for a torque tube. If a parking brake is adjusted just right, applying it judicially will send power to both wheels. |
10-13-2021, 06:29 PM | #5 | |
A discussion is going on over on the Fordbarn early V8 forum now about locking "A" rear ends. https://www.fordbarn.com/forum/showt...4870&showall=1 As a side note, I drove a 32 roadster on the street with a locked rear end for many years and as long as you run normal street tires and get used to the slight chirping on corners, you will never know it is there. |
10-13-2021, 06:42 PM | #6 |
https://www.offroadxtreme.com/news/w...-does-it-work/ These work pretty well, nut are a ton of work. John
As Carroll Smith wrote; All Failures are Human in Origin. |
10-13-2021, 08:05 PM | #7 |
I probably have a set of welded differential (spider) gears that I used when we were dirt track racing Model-As. Let me know if you need a set.
10-13-2021, 11:40 PM | #8 |
To OP Maybe the Jersey Boys were running differential spools in place of the spider gears: See H.A.M.B. thread:
https://www.jalopyjournal.com/forum/...w-what.945845/ |
10-14-2021, 12:20 AM | #9 |
This is the best video I've found to explain a lunchbox locker.
https://www.youtube.com/watch?v=kL0hPEOStGk I've had one for about 10 years in the front of a 4wd. Every now and then it seems that everyone in the car will die a horrible screaming death when it doesn't unlock. |
10-14-2021, 12:21 AM | #10 |
Here is a spool I made for a V-8 banjo rear that uses Ford 9" Axles. Still have 1 or 2 on the shelf.
10-14-2021, 01:00 AM | #11 |
Attached story about the poor man's posit-traction of the 1950's.
Tom Endy https://www.santaanitaas.org/wp-cont...i-Traction.pdf |
10-14-2021, 02:48 AM | #12 | |
The original differential was invented by Leonardo Da Vinci, but I don't think it had spider gears and stuff. His odometer: https://www.youtube.com/watch?v=ARXF_IsqoM4 |
10-15-2021, 12:31 AM | #13 |
Yes, the spool that Dan made is typically what was used by all the dirt track sprit cars running Ford V8 rear end gears in the Hallibrand 201 center sections. The sprit cars drifted around every corner so having a conventional set up was not required and the differential was full time positraction.
10-16-2021, 01:14 AM | #14 | |
He had just finished the last one he ever made. He said each unit took a ton of work and was expensive to make. I tried to ‘bribe’ him to do one more…. No dice ! Some guys, maybe dead by that time, had the ultimate durable non slip hot rod rear ends. He said… never made many such rear ends. Mainly for racers. |
10-16-2021, 10:12 AM | #15 | |
I sure would like to see the "bulletproof" rear end that he made. Does he have drawings, pictures or descriptions? There are others sources to make parts for something that would be popular like this. Thank you. Gene |
10-16-2021, 10:56 AM | #16 | |
starting inside the diff, must bore gear and opposite side to fit late model side gears. this makes room for adding in Posi unit shown above in earlier post. then housings modified for plug in axles, this usually entails changing brake assemblies also. then axles made to fit for length and posi unit splines. there is more room inside the V8 rearends width wise and stronger pinion. currently I run a spool in the B'ville car, late model 28 spline shortened axles. Easy to do with the right equipment, just not too many people have the eq. John
As Carroll Smith wrote; All Failures are Human in Origin. Last edited by johnneilson; 10-16-2021 at 11:01 AM. Reason: added pic |
10-16-2021, 12:25 PM | #17 |
Richard Scaldwell drives a JAP powered Edwardian car with a rear end that does not have a differential. He gets around just fine. Of course, most of the time he is drifting around the corners.
Here is an interview with him and after that a link to an article about him at The Old Motor. In The Old Motor article there is a shot of the rear axle which is nothing more that a straight shaft with chain sprockets. Gear change is accomplished by dog clutches for the various chains. https://www.youtube.com/watch?v=8ks2e_pjasQ https://theoldmotor.com/?p=136808
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 10-16-2021 at 12:45 PM. |
10-16-2021, 02:36 PM | #18 |
Most people don't realize it but if you need a bullet proof, light as possible rear end, it is FAR cheaper to just get a sprint car or midget rear end and bolt it in. Can be had for either cross spring or torsion bars and either closed or open drive shaft. Only one brake to fiddle with also.
10-16-2021, 06:17 PM | #19 |
Gotta love that JAP. I've got a JAP lawnmower.
What helps is the narrow wheel track so there is less difference in wheel speed when cornering and the narrow tyres. My cousin in Tasmania had a VW beach buggy with dual wheels on the back and wide racing slicks on the front with a welded diff. You could steer at low speed, but going faster on the beach the steering was non eventful. It was like a rocket. |
