Old 10-05-2021, 04:55 PM   #1
34 fordor owner
34 fordor owner's Avatar
Default Help I知 Lost
So, I just put on a freshly rebuilt Holley onto my 34 Ford (not correct carb for 34痴 but was on the car when I inherited it) I am getting fuel to the carb and I can see it shoot out the jets. Now that痴 all great but the engine is still not firing even after I have put on a rebuilt distributor, new spark plug wires, new spark plugs, and getting gas into engine. I am at a complete loss. Any help would be greatly appreciated!!
34 fordor owner is offline   Reply With Quote
Old 10-05-2021, 05:04 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Help I知 Lost
Time to get out your multi meter/volt meter. Check for voltage to the ignition switch and
at the coil with the ignition switch turned on....
Old 10-05-2021, 05:14 PM   #3
34 fordor owner
I will have to try this
Old 10-05-2021, 05:44 PM   #4
WRA
WRA's Avatar
What was wrong that caused you to change these parts? Was it a running car beforehand?
WRA is offline   Reply With Quote
Old 10-05-2021, 06:02 PM   #5
34 fordor owner
The car was running about 20 years ago when it was parked. I went through these things as a list to hopefully get it running again.
Old 10-05-2021, 06:12 PM   #6
Mart
Mart's Avatar
Do you have spark if you fit a plug to one of the leads outside the engine?
Like this:
Mart is online now   Reply With Quote
Old 10-05-2021, 06:56 PM   #7
34 fordor owner
Like this:
I tried this on the number 5 spark plug and I did have a spark. Tomorrow I plan to check others. I may even do the spark plug wires over again to ensure I have them correct.
Old 10-05-2021, 10:05 PM   #8
Lanny
Lanny's Avatar
Remember that the #1 cyl. on a Ford Flathead is on
the right front (pass side) of engine, if it is LHDrive.
It's odd to have the #1 cyl., not be the furthest forward,
as the #5 cyl. on a Ford flathead is further forward.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
Old 10-06-2021, 08:06 AM   #9
34 fordor owner
Thank you for this reminder. Something else I was thinking about, is it possible something crawled into the exhaust pipe and has stopped it up? Thank you.
Old 10-06-2021, 08:16 AM   #10
flatford8
flatford8's Avatar
Yes it’s very possible.....it’s almost a guarantee .......but the motor would still fire if you have fuel,spark and air......did the rebuilt distributor come with a new condenser?......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 10-06-2021, 09:05 AM   #11
34 fordor owner
Originally Posted by flatford8 View Post
Yes it痴 very possible.....it痴 almost a guarantee .......but the motor would still fire if you have fuel,spark and air......did the rebuilt distributor come with a new condenser?......Mark
Just got done checking voltages. Starting at the battery there are 6.4 volts and at the coil I am getting 2.4 volts. Mark, condensers for these distributors are crazy hard to find now. I found a condenser with an original strap soldered on.
Old 10-06-2021, 10:01 AM   #12
V8COOPMAN
V8COOPMAN's Avatar
Since it's obvious that you have a later 8BA-type engine and not a '34 ignition system, the schematic someone posted is not representative of what you have. Mac VanPelt kindly posts most of these drawings for our use. This drawing BELOW should be more appropriate for troubleshooting your later distributor/points/condenser. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-06-2021, 10:11 AM   #13
34 fordor owner
I have the dome distributor on my 34 Ford.
Old 10-06-2021, 10:12 AM   #14
34 fordor owner
What is the required voltage needed at the coil like I said I was getting 2.4 at the coil.
Old 10-06-2021, 10:18 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
Duh! I obviously misread Mart's post up above and assumed (ASS-U-ME) that the engine head shown in his picture was yours....SORRY! DD
T5 W/TORQUE TUBE
Old 10-06-2021, 01:30 PM   #16
Lanny
Lanny's Avatar
34 fordor owner, maybe list your location in hopes that
a member might be close enough to come help you
Old 10-06-2021, 02:15 PM   #17
34 fordor owner
I am in Alamance county North Carolina.
Old 10-06-2021, 02:30 PM   #18
Lanny
Lanny's Avatar
Maybe someone close will see this thread, and come and help.
My '40 at one time, years ago, after sitting a long time, would
just spitter and sputter while trying to start it.
An old car guy came over, pulled the front distributor, and filed
and set the points, stuck it back together, and it fired up.
Old 10-06-2021, 03:00 PM   #19
34 fordor owner
Plenty of people in me area that have classics. Might have to stop one and ask for some help. That also sounds kinda like my case usually when I try to start the car, not this recent time though, it would sputter. I had the distributor rebuilt though so maybe the coil. Do you know how many recommended volts is needed at the coil?
Old 10-06-2021, 08:09 PM   #20
34 fordor owner
Does anyone have a good recommendation of where to get a good coil for a dome distributor?
