Old 07-28-2021, 08:17 PM   #1
Paul Mohagen
Default 47 pickup speedometer
does anyone know how to change the speedometer indicator pointer without breaking something.? I have several speedometer to remove a good pointer from .
Paul Mohagen is offline   Reply With Quote
Old 07-28-2021, 10:02 PM   #2
fordor41
fordor41's Avatar
Default Re: 47 pickup speedometer
My '41 speedo pointer was extremely thin. It's just pressed onto the shaft. Gentle does it
fordor41 is offline   Reply With Quote
Old 07-29-2021, 08:21 AM   #3
D. Jones
D. Jones's Avatar
If you have a local clock/watch repair person they can probably remove them for you. They have special pullers for such work. As fordor41 said "gentle does it" as the pointer is most likely aluminum and will easily bend or break.
D. Jones is offline   Reply With Quote
