Old 05-03-2011, 09:53 PM   #1
19Fordy
19Fordy's Avatar
Default 1940 Transmission leak
What causes the gear oil to leak out the rear of the 40 ford transmission and how can it be fixed? Is it a bearing problem? I took my transmission apart in 1970 but I can't recall the inner details.
Thanks.
19Fordy is online now   Reply With Quote
Old 05-04-2011, 06:35 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1940 Transmission leak
the counter shaft for the cluster gear as well as the shaft for the reverse idle gear pass through the rear of the case. Both of these shafts are under oil when in use. There is not a seal or gasket in this area that prevents the gear oil from leaking pass the shafts and the case.
Old 05-04-2011, 08:21 AM   #3
19Fordy
19Fordy's Avatar
Thank you Terry. Any ideas on how I can fix the leak?
Old 05-04-2011, 08:25 AM   #4
rotorwrench
rotorwrench's Avatar
There wasa recent thread about oil, if I remember correctly, that mentioned this problem. The shafts held the oil back by clearance fit only. After many years and many miles, the shaft bores fret slightly which causes them to seep. Mac VanPelt mentioned that he uses RTV on the bore fit and for the retaining pin too. Using SAE 140 lube oil in warmer climates helps too with no apparent problems in shifting gears. Colder climates have to revert to SAE 90 lube oil.
Kerby
Old 05-04-2011, 08:47 AM   #5
George/Maine
George/Maine's Avatar
If that is the same trans since 1970,i would guess its not and unsize shaft.The new shafts some have been reported to be under size as much as .002, they should be plus o/minus only .0005
George/Maine is offline   Reply With Quote
Old 05-04-2011, 08:49 AM   #6
19Fordy
19Fordy's Avatar
Kerby
I even filled the transmission with 600W and it still leaks. Do I need a new case? Are there measurements I could take to see how much the bore is worn?
Old 05-04-2011, 09:58 AM   #7
41ford1
41ford1's Avatar
My pickup has this same problem. You can minimize the amount leaked by running the level 1" below the filler hole. If you do that be sure to check the level frequently.
41ford1 is offline   Reply With Quote
Old 05-04-2011, 11:11 AM   #8
19Fordy
19Fordy's Avatar
Not sure if I understood your reply, but it's the same original OEM transmission that came with the car in 1940.
Old 05-04-2011, 03:57 PM   #9
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
I took the shafts in my '39 and machined O-ring grooves in the ends of the shafts and installed O-rings to seal these shafts, now I have a dry floor under the transmission.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-04-2011, 04:11 PM   #10
36tbird
A while back I read about there being a possibility of a leak around the counter shaft before I rebuilt a box. To hopefully prevent it, the fix was to drill and tap holes in the case around the outside of the counter shaft hole at the front of the trans then RTV it and bolt on a cover plate using the holes. This would fix the front but I don't think you have the room at the rear.
36tbird is offline   Reply With Quote
Old 05-04-2011, 05:04 PM   #11
Ken/Alabama
Ken/Alabama's Avatar
I dont think I would put that 600 weight oil in there,that stuff is for early tranmissions with straight cut gears. Its seeping around the shafts as mentioned before. The biggest pain in the rear is having to pull it out to fix it.
Old 05-04-2011, 08:04 PM   #12
fortyfords
fortyfords's Avatar
My forty did the same thing, put all new seals and gaskets in the trans and sealed the two shafts with red rtv. It lasted for quite awhile but eventually leaked again. I would use the o-ring idea.
fortyfords is offline   Reply With Quote
Old 05-05-2011, 06:37 AM   #13
Terry,OH
Terry,OH's Avatar
there was a fellow on ebay who sold the two shafts with O-ring seals. I believe he may be out of them at this time. I bought a pair from him and mic-ed them, both were spot on size. it is difficult getting the O-ring installed in the case, force will only cut the O-ring. The trans I installed the rings on does not leak.
Old 05-05-2011, 09:03 AM   #14
19Fordy
19Fordy's Avatar
Terry, Is the groove cut so the 0-rings actually compress so they fit in the transmission case casting hole where the shaft goes?
Old 05-05-2011, 01:38 PM   #15
Ken/Alabama
Talking Re: 1940 Transmission leak
I made a tool to do this with so the o-rings wouldnt get cut as they slide in. Made it out of a piece of round stock that just fits in the hole and ground one end so when its inserted in the case it gives the o-ring something to slide on.Works like a champ.
Old 05-06-2011, 09:18 AM   #16
36tbird
Here's a picture of the cover plate I put on a transmission I rebuilt. RTV is used to seal it all and you just have to make sure that the screws securing the plate do not protrude into the inside of the box. I like the idea of the O-rings. I can see putting an O-ring on the rear end of the cluster gear shaft and one of these type of covers on the engine side. I don't see how you can install O-rings on both end of the shaft without the risk of tearing one. Could you chamfer the rear outside hole and grease it with vaseline so that as you slide the shaft in you would not tear the O-ring?
Old 05-06-2011, 10:54 AM   #17
Gary Duff
I O-ring the case, and use Redline MT-90 gear oil, with no leaks and a nice shifting transmission. I cut three grooves, one on the back of the reverse idler shaft bore, and two grooves on the cluster shaft bores. O-ring is 3/32 Buna-N.
Gary
Gary Duff is offline   Reply With Quote
Old 05-06-2011, 12:45 PM   #18
36tbird
Hey Gary, how do you cut the groove for the o-ring? Thanks for the number/size of the ring.
Old 05-06-2011, 03:24 PM   #19
Hamtown Al
Hamtown Al's Avatar
Lucas sells some potent stuff for stopping leaks in auto trans and power steering pumps and they work. You might see if they have something for manual trans. It's worth a try before you get your hands dirty. Just a thought. Good luck, Al
36 Fords Rule! Visit at www.36fords.com.
Hamtown Al is offline   Reply With Quote
Old 05-06-2011, 05:31 PM   #20
19Fordy
19Fordy's Avatar
Al. Could you please post the name of the Lucas "stuff" if possible? Thanks.
