Old 05-02-2021, 09:32 PM   #1
Kpar
Kpar's Avatar
Default 33 Cowl Vent
Got some wet feet on the last run so decided to check things out.
Cowl vent flap was always way below the cowl when closed.
Got a new rubber from 3 gen. Rubber a lot thicker.
Easy job I thought & then found out I'm not as flexible as I was 30 years ago.
to make it worse some bolts were metric, one whitworth and one UNF.
Question,
1. Should I build up the channel before installing the rubber ?.
2. Should I glue the rubber ?.
3. Is the edge facing up correct
Kpar is offline   Reply With Quote
Old 05-02-2021, 09:36 PM   #2
tubman
tubman's Avatar
Default Re: 33 Cowl Vent
Question,
Does this happen often down under?
Old 05-02-2021, 09:53 PM   #3
Kpar
Kpar's Avatar
In central QLD it can happen anytime
Kpar
Old 05-03-2021, 12:44 AM   #4
koates
I have never believed that these reproduction 33-34 cowl vent gaskets were ever made to the correct thickness. You could cut one from thin flat rubber and glue it onto your original repro one to make it a bit thicker so that the vent door sits level when closed with the cowl panel. I would not glue it down in the bottom of the channel because that may prevent any water from reaching the drain hole and tube. I think the edge should face down in the channel so as to allow any water to run under the rubber to the drain hole. The rubber is not supposed to seal into the channel bottom. Regards, Kevin.
koates is offline   Reply With Quote
Old 05-03-2021, 01:03 AM   #5
FlatheadTed
FlatheadTed's Avatar
Kpar As well as Kevin s have a good look at your channel pour some water into it with the rubber out the upper channel should catch any that gets past the rubber if it should fill up then any spill over should be cort by the secondary lower channel and feed out the drain tube ,Lower one is often rusted , the Ones I have fitted I glue the flat side to the lid the lower part seams to fit the channel ,not sure if its right
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-03-2021, 01:10 AM   #6
koates
Keith, not sure there is a need to unbolt the vent door. Should be able to fit the gasket over the door with out unbolting the door. Regards, Kevin.
Old 05-03-2021, 04:37 AM   #7
Kpar
Kpar's Avatar
Kevin I had to unbolt the vent flap as previous builder used a heap of silicone to glue it down. There also seems to be different opinions on which way the ridge faces up or down ?.
Kpar
Old 05-03-2021, 05:09 AM   #8
Lawrie
Lawrie's Avatar
Kieth , have you got the new rubber, I have just got one and you can have it as its so different to tho one fitted to our 33.
If you are removing the flap give me a call so two of us will do it no drama.
I ended up reusing my old rubber.
Lawrie
Old 05-03-2021, 05:51 AM   #9
mercman from oz
mercman from oz's Avatar
Trying to make the Cowl Vent on a 1933 Ford Sedan water tight.
mercman from oz is online now   Reply With Quote
Old 05-03-2021, 08:30 AM   #10
DavidG
DavidG's Avatar
The lip, which is a modern addition to improve the seal should be up, not down. There is no drain hole beneath the channel where the rubber is installed; the drain hole is in the inner channel where there is no rubber seal. Notwithstanding, I never glue my seals in place.
The problem with the replacement seals isn't so much that they are too thick, but rather not soft enough for the lid to form a depression and therefore a good seal. You may have to install the seal and place the cover on it (unattached) and place a serious amount of weight on top of it for a week or so to depress it down even with the rest of the cowl top.
Old 05-03-2021, 03:36 PM   #11
FlatheadTed
,my sedan is not Glued but I notice the seal is shrunk doesn't line up when closing ,
Old 05-03-2021, 06:37 PM   #12
Kpar
Kpar's Avatar
Lawrie
I finally got the flap off but may need your help in fitting it back.
I got the rubber from 3rd Gen with a ridge. Is this where you got yours ?.
Keith
