Anyone have a suggestion on a source for an oil supply line for a Fram external oil filter canister? As you see the flare on the canister side broke and the hose is cracked and getting short for ware. All of my local sources can make me a more "modern" hose which is also bigger and is also $ 50.00. and I hope will fit under the bottom of the canister into the fitting??? I bit the bullet so I can at least drive my car in the interim BUT would like to get something more period correct looking!!!!
FYI One end (The block side) is 1/8" NPT the other (Canister side) is a #4 inverted flare and NOT 1/8" NPT |
You could make it out of steel tubing (fuel line). Both ends are fixed so should be OK. It's short so tight bends are difficult would be the hardest part.
It looks like a firewall mounted filter in which case you do not want rigid lines.
I would use Aeroquip as it looks a little better than rubber hydraulic hose and crimped ends
Markdtn when making ridged lines you should make a coil with a few loops to take up any movement .
Thanks for the opinions, I think I'm gonna just delete it from the car as they aren't that effective anyway!!!
Disagree with "aren't that effective", but on the other hand, flatheads were driven for years without filters. If you change the oil often it should be fine.
#10 | |
I don't know where you got the information that they weren't that effective. Bypass filters actually are more effective than full flow filters for two reasons: First, they trap finer particulates than full flow, and second, full flow filters must pass oil unfiltered should the filter get clogged up, while a bypass filter can simply stop the flow.
Alan |
I'll go a step further and say that the way the vast majority of these cars are used and maintained, a bypass filter is superior to a full flow filter.
Rockfla:
Since you already have the canister, use it by using 1/4 in. steel fuel line with a loop in it to absorb any vibration. A flathead engine is solidly mounted and doesn't "rock and roll" so as to create a problem. Or, use a filter that bolts to the head bolts/ studs. They are plentiful. Also, you could leave the filter canister you already have on the firewall but, install a rubber pad under it to absorb vibration. Those OEM filters do work well. Another idea is to modify the Fram filter by adding a 3 hole base from an old Ford OEM canister. It would be easy to do if you have access to a welder. |
#13 | |
#14 |
I used 1/4 inch nickel/copper brake line from NAPA for my oil filter lines. They bend easily without kinking and are easy to use. I am not concerned with originality.
#15 | |
Agreed and aesthetically they look horrible. Just change the oil on a regular schedule and you will be fine.
"Sometimes he would accuse chestnuts of being lazy, the sort of general malaise that only the genius possess and the insane lament." |
#16 |
wrong!
#17 |
It's not wrong! It's WRONG!!! If you are going to do the angry pirate tubman, at least do it correctly.
#18 | |
Also, thank you for agreeing with me.
#19 | |
WRONG
#20 |
Reminds me of Waylon,,,,,,,Wrong,,,,wronggg !
LoL Tommy |
