04-04-2021, 04:26 AM | #1 |
Plug connector options?
I just got my Winfield head installed, and it turns out that, because the Winfield locates the spark plugs between the valves, the stock plug connectors are just barely too short to connect plugs 1 and 4 to the distributor body.
Does anyone have a suggestion for an alternative connector that will work with the stock distributor? I can get 7mm wire and crimp some terminals, I guess, but I'm not sure what terminal type would work best. |
04-04-2021, 05:43 AM | #2 |
Re: Plug connector options?
Even for a standard head, I lengthen the leads by cutting them and soldering in what ever length is needed to do the job. I use a piece of shim brass to do the job. I always lengthen #3 lead so I can get it clear of the body enough to prevent the infamous Model A #3/#4 cross over and no body has noticed yet.
Hope that helps!
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 04-04-2021 at 08:06 AM. |
04-04-2021, 07:37 AM | #3 |
3 X spark plugs ? I bought new 3X plugs( the forums said they run so much better) and the connectors where almost to short, to close the the cap body. Well my a didn't run well so I bought the champion replacements and they are about 1/2 in taller, no more clearance issues! My head is the 6.0 hc Snyder
04-04-2021, 08:07 AM | #4 |
No, it's the W18Y. The connectors would work if the plugs were about two inches taller, but I'd rather get longer wires.
I don't have soldering skills unfortunately. |
04-04-2021, 08:15 AM | #5 |
Purchase some brass shim stock and make/cut your own.
04-04-2021, 08:52 AM | #6 |
https://www.macsautoparts.com/spark-...09651657eea338 Last edited by Y-Blockhead; 04-04-2021 at 09:03 AM. |
04-04-2021, 08:59 AM | #7 | |
Oh look, there's a fordgarage.com page. Of course there is. Update: Woohoo, $10 on eBay shipped. I love the internet. Last edited by alexiskai; 04-04-2021 at 09:05 AM. |
04-04-2021, 09:08 AM | #8 | |
https://www.macsautoparts.com/spark-...09651657eea338 |
04-04-2021, 09:14 AM | #10 |
04-04-2021, 09:17 AM | #11 |
I thought about that. Plan B was to get generic plug wires at AutoZone and crimp new terminals on ‘em.
04-04-2021, 09:38 AM | #12 |
Beware running a manual advance distributor with a high compression head...as compression goes up,the engines tolerance for timing deviation reduces.
04-04-2021, 09:41 AM | #13 |
I'm using the modern cap and wires with my Winfield head.
04-04-2021, 09:43 AM | #14 |
Bailing wire works.
04-04-2021, 10:58 AM | #15 |
04-04-2021, 11:28 AM | #16 |
the gyro? best map it with a timing light..
04-04-2021, 11:42 AM | #17 |
I haven't worked with timing lights before. What am I "mapping" exactly?
04-04-2021, 08:53 PM | #18 | |
04-04-2021, 09:11 PM | #19 |
You use a pointer and a degree reference for the crankshaft pulley, nurex has them. Then use a cheapie tach dwell meter ,it reeds rpm off of the points. Once those two are set rig the timing light and start the engine.. The strobe from the light on the pointer will tell the nurex advance.. per rpm.. the model a ford engine performs optimally at 1 degree advance per 100 rpm...so at 500 rpm or idle,5 degrees, it should read 10 degrees at 1000 with a maximum advance at 24 degrees..By check the advance at various rpms you are basically mapping the timing..something I would definately do with the gyro,
04-05-2021, 12:38 AM | #20 | |
http://www.fordgarage.com/pages/nurexadvance.htm Last edited by Y-Blockhead; 04-05-2021 at 12:53 AM. |
