Hi,
Replacing rear and front motor mounts on 1930 model A keeping original concept that rolled off the line. I may have to slightly spread frame to move rear mounts to replace . Need a suggestion for a frame spreader something old school setup. I really don’t want to spend $150 for a frame spreader, l will most likely use once. Any help would be appreciated. |
#2 | |
Oldford,
Where are you located? Maybe there is someone nearby that can lone you one. Jason |
In Model "A" production movies, a worker with a long and stout pry bar guides the engine into the frame.
Bob Bidonde |
Hi-Lift jack works fine. Also useful for pulling posts.
I used a couple of blocks of wood inserted between bell housing and frame; I tapped these in gently with a hammer until I had enough clearance to replace the mount. It’s not hard to do, go slow and easy. Good luck - Jim |
When I changed rear motor mounts, I ended up on bolting the cowl bolts, as I t seemed they were stopping the frame from spreading.
I always use some 2 x 4s, and my spring spreader. Usually someone in the local club has one. If changing in the car, do one side at a time, starting with the drivers side (way harder). Use some scrap wood, and a bottle jack sourced from Harbour Frieight. It's cheap.
#9 | |
Several possibilities above, many other clever ways, but don't be so sure you need one. My truck went together easily without one. A bit of prying by a helper should do it.
It works, but you do have to really crank on that wrench...
i always used a portapower than u have it for other things
#13 |
I used a port-power for removing/installing the motor. It would be nice if it could be moved a little closer to the motor mounts.
Kevin |
#14 |
A hydraulic jack placed sideways and some 2 x 4's
#15 |
#16 | |
