Old 03-31-2021, 04:29 AM   #9
Wick
Wick's Avatar
Default Re: Light / Horn Switch
Buy a greasy original light switch. Clean it up and use it. Place a yard stick across the steering wheel to hold the horn button down /light switch. Find a original spyder,make sure it goes All the way on.
When done right,you will hear and feel the switch Click when you turn on the lights.
Also it's important to have very good grounds on both headlight housings.
Wick is offline   Reply With Quote
