Old 03-26-2021, 06:21 PM   #1
alanwoodieman
Default trunk rack
I am new to A's. trying to mount a luggage rack to a 2 door sedan with rear mounted spare--I think I need two brackets to move the luggage rack back from the spare---could some one school me on this?
Old 03-26-2021, 06:40 PM   #2
tomscott
tomscott's Avatar
Default Re: trunk rack
I just added a rack to my Tudor sedan this winter.
I bought the extension brackets needed from Snyder’s.
Easy installation.
Tom
tomscott is offline   Reply With Quote
Old 03-26-2021, 06:47 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Don't cheap out on the extension brackets!! Snyder's sells two versions. There is a bit of weight back there and it will move around with the cheapies.
https://www.snydersantiqueauto.com/P...earchByKeyword
Old 03-26-2021, 08:45 PM   #4
Doug Linden
Doug Linden's Avatar
I have used the extension brackets that Bratton's sells and they are very well made and fit well.
https://www.brattons.com/sedan-lugga...dans-only.html
Doug Linden is offline   Reply With Quote
Old 03-26-2021, 08:49 PM   #5
alanwoodieman
thanks for the advice, it was sorely needed, how about a picture of these mounted to car. thanks
Old 03-27-2021, 08:24 AM   #6
KenBolton
I must have gotten the cheap extensions as the rack sagged with the trunk + contents. Made reenforcing brackets.
KenBolton is offline   Reply With Quote
Old 03-27-2021, 06:25 PM   #7
Gene F
Gene F's Avatar
I have the good quality ones from Snyders. They have been on my car at least 20 years. The trunk still does not droop. When we go on trips we put our clothes in that trunk. A nice trunk just adds a little something to the looks of the car. It's like it gives it that finished look.
Old 03-27-2021, 07:16 PM   #8
Cape Codder
Cape Codder's Avatar
I used the Heavy Duty brackets and then went over board and used Grade 8 Bolts to mount all of it!
Cape Codder is offline   Reply With Quote
Old 03-28-2021, 12:00 PM   #9
Ed Wendell
Ed Wendell's Avatar
Alan, we used the heavy duty extension brackets from Snyder's. Trunk is full and sits fine.
The side brackets were loose so I added nylon washers to each bolt. No more rattle.
Ed
Ed Wendell is offline   Reply With Quote
Old 03-28-2021, 04:27 PM   #10
Doug Linden
I'm also using the Snyder's Luggage rack extension. Work and looks fine.
