Old 03-10-2021, 06:05 PM   #6
51504bat
51504bat's Avatar
Default Re: 1955 Rear Axle Pad Width
Don't know what the axle tube diameter your rear end is but the tubes on mine were I believe 2.75. I could find 2.5 and 3.0 inch pads but 2.75 ones were not available from all the usual suspects. Turns out the guy who set up the 3rd member had them in stock. So if you can't find the correct ones for your rear end Bill Thomas Enterprises in San Bernardino, CA should have what you need as well as any other rear end stuff as well.
https://billthomasenterprises.com/
(909) 888-7949
