Old 03-09-2021, 08:38 PM   #11
Terry Burtz, Calif
Default Re: The Terry Burtz 5 main bearing engine blocks are back on track.
The ship carrying the new engine kits is being unloaded at the dock in Los Angeles. We are expecting to have kits ready for pick-up or shipped from the warehouse in Hawthorne, CA around March 22, 2021.
Syncro, The bearing inserts chosen for the new Model A engine were used by GM from 1955 until 2003 in 265, 283, and 327 V-8 engines, 194, 230, and 250 straight 6-engines, and 122, 140, and 153 straight 4-cylinder engines.
These engines were used in Buicks, Cadillacs, Checkers, GMCs, Isuzus, Oldsmobiles, and Pontiacs.
If you go to https://www.jegs.com/i/Sealed-Power/844/2020CP/10002/-1 and click on "Vehicle Fitment" near the bottom left of the page, 201 pages will open listing 2410 different vehicle makes and models that used the 2020CP insert.
If any of the engines listed above were used in Australia, it will likely use the 2020CP bearing insert.
Terry Burtz, Calif is offline   Reply With Quote
