Old 02-21-2021, 10:52 PM   #1
Himi52
Default 1939 right rear drum install
I have a Model A that had been converted to hydraulic brakes. I am trying to install the right rear drum. I cannot get it on. The brake shoe is not allowing the drum to be installed. Any tips for installing the drum? Thanks
Himi52 is offline   Reply With Quote
Old 02-21-2021, 11:42 PM   #2
bbrocksr
Default Re: 1939 right rear drum install
Are the brake adjusters backed off? Axle key lined up?
Bill
bbrocksr is offline   Reply With Quote
Old 02-22-2021, 01:28 AM   #3
Himi52
I will check that tomorrow. Thanks
Old 02-22-2021, 02:44 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
The axle key should have tapered end INBOARD, with the beveled side of key DOWN in the slot, toward axle. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-22-2021, 08:01 AM   #5
Veeder
I love the plane pic
Veeder is offline   Reply With Quote
Old 02-22-2021, 08:16 AM   #6
rockfla
rockfla's Avatar
Most likely you have two adjusters both bottom and top SO make sure you adjust both of them inward. I always try and make sure the key way is either at the "12" or "6" position, that way its easy to orient the drum when sliding it back on!!!
Old 02-22-2021, 08:38 AM   #7
Mart
Mart's Avatar
In this instance I would remove the key and the brake shoes. I would fit the drum and make sure it fits properly with the correct relationship to the backplate. Once that is deemed to be ok I would fit the key and make sure the drum fits ok again. Then fit the shoes and make sure all the adjusters are fully released. See if the drum goes on ok.
There have been instances of incorrectly shaped repro brake shoes. If you have old parts try those. There is also a situation where the shoe reliners assume the drums will have been skimmed out. It can then be difficult to fit the drums if they are std 12.000"
Do some investigating and come back with your results.
Old 02-22-2021, 09:44 AM   #8
rockfla
rockfla's Avatar
Another "Helpful" tip as I just learned......Install the pins for the E-brake arm and E-Brake actuator arm for the shoes from the backside (backing plate) OF the shoe and the horse shoe clip on the outside (Or Drum side) of the shoe. Put the pins in, then slide the clip on to HOLD the pins in place, THEN hook your spring between the shoes, THEN pull the clips off the pins, slide your finger behind to hold it in place and slide the E-Brake actuator ON and lock in back in place with the clip. THEN slide the E-Brake arm in to the actuator slot THEN on to it's pin and lock it in place with the clip. Then hook your E-Brake cable to the arm..... It's way easier that way!!!! ASK me how I know!!!!
ALSO IF you have the old shoes compare your new ones to the old ones.....The new ones MAY be a little longer where it goes into the wheel cylinder SO you might have to grind down those tabs just a little bit to get the shoes fitting right!!!!
Old 02-22-2021, 01:56 PM   #9
tinkirk
tinkirk's Avatar
make sure your parking brake is released
tinkirk is offline   Reply With Quote
Old 02-22-2021, 03:04 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
For Veeder ....just a little more to appreciate. That's an old 1940s Cessna T-50, just like Sky King's FIRST airplane. DD
T5 W/TORQUE TUBE
Old 02-28-2021, 12:15 PM   #11
Himi52
Here is the picture of my right rear brake. Will try to work in it today.
Old 02-28-2021, 12:47 PM   #12
Mart
Mart's Avatar
In the picture it looks like the emergency brake is not fully retracted. That will stop the drum going on.
Old 02-28-2021, 01:23 PM   #13
Himi52
I bought this truck in 1968 before I had a driver’s license. Got it running changed the mater cylinder bled the brakes and was good to go. When I went to change the wheel cylinders I noticed in the rear brake the emergency brake cable was never attached to the arm. Thanks for the heads up. I will check the emergency brake for it is fully released.
Old 02-28-2021, 01:39 PM   #14
Bob C
Also be sure to clean all that grease off the axle and hub taper, needs to
be squeaky clean.
Old 03-06-2021, 07:45 PM   #15
Himi52
Hi,
Finally had some time to work on the brakes. I disconnected the parking brake and adjusted the shoes in a bit and finally got the hub on. Thanks for all your help and worthwhile suggestions. I am very appreciative. I will keep you posted on the progress on getting it going again.
Old 03-07-2021, 12:32 PM   #16
Charlie Stephens
Did you arc the shoes?
Charlie Stephens
Old 03-07-2021, 01:08 PM   #17
Himi52
The shoes to my knowledge have not been arched. They are the shoes that came with the car in 1968. They are barely warn. Should I have them arched?
Old 03-07-2021, 01:29 PM   #18
marko39
Not if they are worn but a good idea on new shoes.
marko39 is offline   Reply With Quote
Old 03-07-2021, 07:15 PM   #19
miniceptor86
miniceptor86's Avatar
I likey!
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 03-07-2021, 11:55 PM   #20
Tinker
Tinker's Avatar
torque that baby down to 180-200lbs. If you don't have a torque wrench that high get a long pipe and put it on your wrench and jump on it Key set is important as mentioned.
