The pressed steel bell housing used on some 51/53 flatheads , what is the correct installation of the clutch arm , you have the clutch arm , the spring that goes over it , then there is A metal plate that also goes on the arm and goes to the outside of the bell ,then there is a felt material that goes under the metal plate , is this correct .
This is from Van Pelt's.
#3 | |
First, the stamped steel full bell was only used on '49-'51 Ford cars. You are correct about the assembly: Clutch arm, anti-rattle spring 7562, plate 7513, and pad 7996. The '49-'51 shop manual shows the entire assembly. |
Thanks , question ,why is the pad used ? got one with the bell and was falling apart ,do I need the pad , going to use this bell on my 53 f-100 that I am installing A S-10 5 speed , I can fab and weld rear mounts to the steel bell ,that is why Im using that bell., with an adapter from offenhouser.
Make sure you have the correct angled started plate that only works with the stamped bell. |
