#21 |
#22 | |
Super Moderator
I had, in a previous post, given all the information from the NAPA site I found today. And, it now appears others have found the same.
#23 |
If you use the number Kube uses, RAY 2449609, it is $57, but it say that one is for a mid 50's Ford. Will that also fit the earlier flatheads?
#24 | |
PLUS....Free Shipping to your home, via the link above.....Dayum! DD $57.99 /Each Pickup In Store Tomorrow We'll notify you when ready for pickup Ready to Ship to Home Qty: 1 FREE SHIPPING on orders $35 or more |
#25 |
Super Moderator
Something strange is going on here. When I look up that number, it shows 1948 Ford.
#26 | |
Edit: Wait, fellas. Look at the mounting flange for in the picts. in the link. It may not be correct. https://www.napaonline.com/en/p/RSE2449609 Last edited by Tim Ayers; 03-03-2021 at 04:05 PM. |
#27 |
ford went to 12 volts in 56, thats the starter used to convert the older ones from 6 to 12
#28 | |
Still watching for how this turns out though!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
#29 |
Interesting. I'll report back once I pick it up. Would be great if it's 12V. I can swap over from another one I have.
#30 |
Super Moderator
ray 2449607
#31 |
#32 |
Look with what we deal with in Canada.
https://www.napacanada.com/en/search...onEnabled=true I believe in buy local but not when they do this. $323.27 + 27.01 core charge plus 15% sales tax. $402.82 cad or 300USD! Rock auto is less than half. And that didn’t include core charge. Last edited by 36coupe; 03-04-2021 at 07:53 AM. |
#33 | |
#34 |
#35 |
I've been looking into doing just that.
#36 |
#37 |
I went ahead and bought the 12V 56 Ford model - as I want to go through the conversion process with a 6V core and see how things work out.
#38 |
send the starter to auto electric in greenville, sc. they have been rebuilding them since 1949 and Glenn gets them right!! I know he does about 10 starters for me each year for customer cars
#39 |
I picked up the $57.00 12V Y block starter. Totally different than a flathead. The picture was accurate. Armature shaft is longer and thinner. No cut to a woodruff key and case is different. Oh well. I'll put on my table at Hershey. No returns since it was special order and an electrical part.
#40 |
you use that outer case, with your 6v armature, and now you have a 12v flathead starter
