#21 |
I have a "Lift King" 4 post, 7000 lb, hoist, bought used in very good shape, and I'm quite happy w/it. Moved it home all assembled on my 14' car hauler trailer. Shoulda took a picture.
I bought used because of the price, about 1/2 of new.
#22 |
Great ideas guys. Keep them coming.
Looks like I am going to have lots of reading this weekend. Interesting how backyard buddy and advantage are both from the same company. They advertise the "buddy" as made in USA. I don't see that on the advantage line. I wonder if that is the same lift but made overseas?
1930 Standard Coupe |
#23 |
I have had 7 different 4-post lifts. All of them have worked great!
#24 |
Having worked around both types, for doing any real work on the car I would go with the 2 post. The 4 post in my OP would be fine for general maintenance and storage but all those post and rails I find to be in the way. I took a look at some of the sites that sell the 4 post, you don't see many touted for working, most every one shows cars being stored. If you want to change tires or do brake work or ?, you then have to buy more "stuff/things" to lift the car up off the rails if it does not come with them. One site I looked at, those jacks run $800 to $1600 more over the cost of the lift. that may be the top end prices, I only check one.
I was just thinking about how nice it would be to have a 2 post lift today before I read this, wishing I had space for one for.
#25 | |
The Advantage Lift is built in China (the only thing I don't like about it) but is much heavier than the Backyard Buddy I looked at a few years ago. I made a couple of calls before I bought and asked where it was built. The answer was China but made heavier with thicker steel than the competition. It does have the post completely encased by the beam rather than the slot. It would be nice to be able to check them out in person before purchasing. TOB |
#26 |
#27 |
I'm too old to crawl on the ground to place the arms on a two post lift
#28 | |
I suppose I should have walked over with cash in hand!!! |
#29 |
Like brokenspoke wrote, because of age, it hurts too much to get down on the floor, position lift arms, and get back up like I’d need to do with a 2 post lift. With the four post, jack positioning can occur at a more comfortable height when wheel removal is necessary. On top of that, nice to be able to observe clearances for exhaust, etc., with the vehicle weight supported by the suspension.
2- versus 4-post arguments will be with us until anti gravity lifts are invented. Everyone needs to decide what works best for their needs. |
#30 |
Without jacks both front and rear a 4 poster is just for oil changes and extra parking space. Also safer on the floor no torsion and faster to get on and ready to lift.
2 post is major pain to set up and not as safe. |
#31 |
What are the recommended bay heights for these lifts?
#32 |
I have 2 Rotary 4 posts lifts. No issues and very safe .
#33 |
I would say 10’. You want enough height to be able to stand under the car when you are working on it. If you are ok with being bent over while working on it, then you could get by with less height. For storage purposes, you add the height of the top car, the height of the bottom car + approximately 6” and that will tell you the overall height needed.
#34 |
My shop has 12' side walls and 17' in the center. My lift has 6' 10" under the tracks at full height and a truck (F350) is probably another 6-7 ft so I would need a minimum of 12' and someone to watch to make sure I stopped the lift before I reached the top. Of course if you were lifting a car on a standard height lift you probably would be ok with 12'.
TOB |
#35 |
I bought the two post lift. The idea of being able to remove wheels, brakes, suspension, etc. without using jacks is just too good of an idea to me.
https://www.garageappeal.com/dannmar...two-post-lift/
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
#36 |
How often do you remove the wheel, suspension?
#37 |
if you like restoring cars- often. |
#38 |
ANY lift is better that no lift. Buy what suits your needs. If you want to store cars on it and do general maintenance (grease and oil changes), I would get a 4 post IF you have the room. Of course you can do those things on a 2 post but setting the arms can be a PITA ESPECIALLY on cars low to the ground. I went with a 2 post for a couple of reasons. The 2 main ones were 1-I didn't want to dedicate the floor space for a 4 post and 2-I wanted the ability to lift off car bodies. The 2 biggest advantages of a 4 post IMO, is that you don't have to set the arms and you don't have posts beside the doors. The beauty of that is that when doing under dash wiring you can lift the car to a comfortable level and stand beside it and reach up under the dash rather than being a contortionist all twisted up and upside down in the cab.Of course, on the flip side, to do wheel work you need jacks with a 4 post As far as safety goes, if you question your own ability to set the arms correctly you probably can't set the jacks required for wheel work on a 4 post safely either and maybe working on cars isn't for you. Would I trade my 2 post for a 4 post??. nope. If I had the room would I add a 4 post to the shop?, in a heartbeat.
#39 |
FWIW, my shop is 32' X 60' w/a 13' ceiling.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 02-13-2021 at 11:11 AM. Reason: Corrected typo |
#40 |
Anyone use the max Jack 2 post lift? I like the idea of being able to unbolt from Floor and with the attached wheels move the post out of the way when I need the room in my small garage.
