Old 02-03-2021, 09:57 PM   #1
Davew
Davew's Avatar
Default How do I wire up a B distributor
I have a B distributor and would appreciate some help in wiring it up. There is all kinds of information on timing but can’t find a picture of where the ignition switch wire goes. Thanks
Davew is offline   Reply With Quote
Old 02-03-2021, 10:50 PM   #2
Jack Shaft
Default Re: How do I wire up a B distributor
There's an arm sticking out that you can adjust,on the end of that arm is a screw,it goes under it.
Old 02-03-2021, 10:57 PM   #3
CWPASADENA
CWPASADENA's Avatar
A "B" distributor will not work with an original Pop Out Switch. You will need a simple "off-on" switch.
Run a wire from the terminal on the outside of the "B" distributor to one terminal of the Ignition Switch. The wire that originally attached to the Pop-Out switch goes to the other terminal on the "Off-On" ignition switch. All the other wiring is the same as stock Model A.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-04-2021, 11:05 AM   #4
Davew
Davew's Avatar
Thanks for the help. Was wondering what that arm was for
