Old 02-03-2021, 05:03 PM   #1
A V8 Al
Default 1935 Pickup mechanical brakes
When adjusting the brakes, which direction do I turn the adjuster on the rear of the backing plate to tighten the brakes ( when looking at the adjuster from behind the wheel). When I turn the adjuster, in either direction, the brakes go from on to off over and over as I turn the adjuster. Whats up? Thanks in advance guys.
A V8 Al is offline   Reply With Quote
Old 02-03-2021, 05:10 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: 1935 Pickup mechanical brakes
Assuming all other pieces are correctly adjusted and within tolerances, the adjuster turn inwards to increase and outwards to decrease braking action.
Here's a little light reading for you. https://www.fordbarn.com/forum/showt...=289449&page=1
and https://www.fordbarn.com/forum/showt...47#post1955947
-Jeff H
Old 02-03-2021, 06:54 PM   #3
Bob C
As you turn the adjuster the brakes may get tighter when you are on the high part of the adjuster and looser in the low spot.
