01-27-2021, 10:08 PM | #1 |
B Pillar Coupe vs Sedan
Guys,
Wondering if the B Pillars are same for a Coupe and a Sedan on a 30-31? Thanks! Jim |
01-28-2021, 12:47 AM | #2 |
Re: B Pillar Coupe vs Sedan
The doors are different widths if that helps. What are you trying to do?
01-28-2021, 08:35 AM | #3 |
I'm just seeing if all B pillars are the same for a coupe or a sedan? The post behind the door.
01-28-2021, 11:56 AM | #4 | |
The basic answer to your question is they are different. The 45B Coupe uses the A-46680-B/A-46681-B Pillar whereas the 55B Tudor uses the A-56674-B/A-56675-B Pillar. |
01-29-2021, 08:06 AM | #5 |
Seems that no matter what the correct term for the part in question, most of us will still refer to the part as THE B PILLAR.
01-29-2021, 10:10 AM | #6 |
Otherwise it’s a pretty tough search |
01-29-2021, 11:01 AM | #7 |
Now I see the question was about 30-31!
