Old 01-15-2021, 07:04 PM   #1
jwaldrich
jwaldrich's Avatar
Default Won't Start when Warmed Up
Anyone else ever have this problem and if so how did you fix it?
Turns over fine and starts up when cold.
Run to town (10 miles), shut it off, pick up whatever from the store, hop back in 5 minutes later and it TURNS OVER SO SLOW IT IS LIKE THE TIMING IS TOO FAR ADVANCED.
Once it has cooled off she starts up as advertised.
Screwed with the timing until I'm sure that isn't it.
Thoughts?
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 01-15-2021, 07:12 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Won't Start when Warmed Up
An easy thing to check is: next time it won’t start, pour about a half a bottle of water on the carb bowl. If that fixes it, your carb is getting too hot. Good luck.
Old 01-15-2021, 07:24 PM   #3
jm29henry
jm29henry's Avatar
Jack, that is why I love reading your replies ! Simple ,factual ,and honest good luck mr drich please let us know how it works out
jm29henry is offline   Reply With Quote
Old 01-15-2021, 07:37 PM   #4
jwaldrich
jwaldrich's Avatar
Will give it a try. Already have two phenolic spacers in there trying to prevent that very thing.
John from Kapowsin
T&A Guy
Old 01-15-2021, 07:50 PM   #5
J Franklin
J Franklin's Avatar
Maybe it would help better if you poured the cold water over the hot starting motor. I can't see how a hot carb would make it crank over too slowly.
Old 01-15-2021, 08:18 PM   #6
jwaldrich
jwaldrich's Avatar
Brain fart.
How does that help the engine turn over like it does when it is cold?
John from Kapowsin
T&A Guy
Old 01-15-2021, 09:30 PM   #7
bobbader
Could be a bad battery cable or cables. Age & corrosion could be one factor. They can look OK on the outside but heavily corroded under the insulation. Diameter of the cable is another problem. Starter cable should be #1 or #2 (Not #4 or 6 as on a modern 12V car). Poor or corroded ground to the chassis can also be to blame. Every so often, It's a good idea to remove the ground cable at the chassis and wire brush or sand the area around the mounting hole on the center crossmember. Should be nice, shiny bare metal to continue to be effective.
bobbader is offline   Reply With Quote
Old 01-15-2021, 09:32 PM   #8
31 Woody
31 Woody's Avatar
Sluggish to turn over hot?—I would check the ground cable at both ends—battery and frame connection. The frame connection is often overlooked. Similar to what bobbader said!
Experience is a cruel teacher. It gives the exam first, then the lesson.
The first 4 hours of a 30 minute repair job are the worst. The next 2 hours usually go much better.
31 Woody is offline   Reply With Quote
Old 01-15-2021, 10:01 PM   #9
Mulletwagon
Mulletwagon's Avatar
If not a cable/connection/battery problem might be a starter issue.
Mulletwagon is offline   Reply With Quote
Old 01-15-2021, 10:59 PM   #10
Terry Burtz, Calif
If a newly rebuilt engine, the piston to cylinder wall clearance may be too tight.
Terry Burtz, Calif is offline   Reply With Quote
Old 01-15-2021, 11:15 PM   #11
700rpm
700rpm's Avatar
That was my problem with my coupe. The clearances mfg specified on current rings and pistons are incorrect for Model A, at least when sleeved back to standard.
Ray Horton, Portland, OR
Old 01-16-2021, 12:05 PM   #12
jwaldrich
jwaldrich's Avatar
New starter but I'll check the connections for corrosion.
John from Kapowsin
T&A Guy
Old 01-16-2021, 12:27 PM   #13
marko39
You could check voltage to starter both cold and hot when it cranks slow. Should tell you where the trouble is or at least narrow it down.
marko39 is offline   Reply With Quote
Old 01-16-2021, 02:11 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Check your grds as well. It definitely is the cables, connections, or even tho new, the starter.
Just an after thought, your not overheating are you?
Old 01-16-2021, 06:38 PM   #15
McMimmcs
McMimmcs's Avatar
I had the same problem exactly and newly cleaned cable connections and a new ground cable corrected it immediately.
Old 01-16-2021, 06:43 PM   #16
Gene F
Gene F's Avatar
Likely causes. 1) starter is overamping. I have seen this many times in cars from the 60s, and 70s. 2) the battery sulfated? - not likely 3) try backing the cable that goes into the distributor out 1 and 1/4 turns or so. 4) corroded battery connection.
Does it start fairly easy with the hand crank when it gets fussy like this?
GENE
Old 01-16-2021, 09:45 PM   #17
Big hammer
Thoughts?
Turns over so slow like the timing is too far advanced. You are retarding the timing with the hand lever before trying to start? Why I ask at car shows I see people leave the advance lever for running! I have gotten in the habit of moving the levers up, gas off, and after the carburetor runs out of gas I turn the key off.
get a bigger hammer tap done
Old 01-16-2021, 09:57 PM   #18
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
If it does it again , place your hand on coil and check if it is hot. Defective coils act like that, also check the battery cables. Could be both.
dansluck is offline   Reply With Quote
Old 01-16-2021, 10:02 PM   #19
700rpm
700rpm's Avatar
I’ve had this coil problem also.
Old 01-16-2021, 10:55 PM   #20
Anteek29
Anteek29's Avatar
"TURNS OVER SO SLOW IT IS LIKE THE TIMING IS TOO FAR ADVANCED."
Hmmm...tells me the problem resides in the electrical system or perhaps tight engine clearances - not ignition!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
